Maxxis Tires
  • 12 Replies
  • 2126 Views
Offline max-zr2
  • 45
Maxxis Tires
« on: September 13, 2012, 07:49:03 AM »
Anyone running bighorns? Looking to invest sometime soon, but leaning farther and farther away from an A/T, this seems to be a slight middle ground between A/T and M/T 's. I live in Northern Ontario (CAN), and will be dealing with a variety of terrain.   Need something that can take some snow too. Any thoughts or other suggestions would be greatly appreciated.
- max-zr2
Installed:
- Jeff's 2" coil spacers,  Doestech shocks (21.5-13.5),  free wheelin' hubs, 15"X8" American Racing rims (4"backspacing), 30X9.5 General Grabber AT2's, K&N Filter, Snorkel,  XL-7 Rear springs
Installing:
- 2" BL
Offline crewcabrob
  • 348
Re: Maxxis Tires
« Reply #1 on: September 13, 2012, 08:11:31 AM »
Hi,
I ran Big Horns on my 2011 GV for about 3 weeks and then took them back and got different tires.  I loved everything about the tires with the exception of the noise.  They droned at every speed except for 0-10mph.
I sure wish I could have kept them, but they were just so loud I couldn't make it work anymore.
Rob
Offline max-zr2
  • 45
Re: Maxxis Tires
« Reply #2 on: September 13, 2012, 10:08:25 AM »
Thanks for the input rob,    if you don't mind me asking, what did you switch to? Im leaning quite heavily towards 30's, so the options are slightly limited.
-Max
Installed:
Installing:
- 2" BL
Offline crewcabrob
  • 348
Re: Maxxis Tires
« Reply #3 on: September 13, 2012, 10:16:16 AM »
I went with Good Year Duratracks.  I have a lift on my GC, so I was able to fit a slightly larger tire on mine.  I love the Duratracks, but now they are starting to get loud too.  I need to have them rotated and balanced.  Once that is done, I bet they quiet back down for a while.
Rob
Offline hcgalvin
  • 1695
    • Granite Path
Re: Maxxis Tires
« Reply #4 on: September 13, 2012, 07:10:03 PM »
We're running the Bighorns, 245x75 R16. They've been great so far, good traction. I would say the noise is typical for a traction tire. It's quiet enough with the windows up.
The cost made them worth it. At our local Les Schwab, there was about a $80 difference between these and the Toyo MT's, PER TIRE.
Heather Galvin
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: Maxxis Tires
« Reply #5 on: September 13, 2012, 07:13:06 PM »
How about Mastercraft Courser C/Ts?  Kind of a cross between an AT and a mild MT tire.  They give off just a slight hum at highway speed, the blocks are siped and they track well on wet roads and through puddles on the road.  I'm betting they go good in the snow too.  You can pin the tread for winter too.  Reasonably priced and they seem to be wearing very well on my truck.  I have right at 10K on them.  Just a thought.
Offline max-zr2
  • 45
Re: Maxxis Tires
« Reply #6 on: September 13, 2012, 07:43:23 PM »
That is another one im looking into. Thanks for the suggestions, and keep them coming guys!
Installed:
Installing:
- 2" BL
Offline talonxracer
  • 1284
Re: Maxxis Tires
« Reply #7 on: September 14, 2012, 05:00:37 AM »
I didnt want a radical mud tire for my Kick, but most of the AT's out there are not much more than a all season street tire in larger sizes. I went with the Procomp MT's, a less aggressive, siped and pinned for studs mud tire. 8K miles now and they are about 30% worn out. When brand spanking new they were awesome in wet, snow, ice, rock and mud, but the sipes wore down very quickly and have lost any advantage they had over other mud terrains. The ride into town is 23 miles with half of that being dirt back/fire roads, by the end of last years winter(which was very mild) the Procomps were kinda scary on the frozen icey dirt roads. I will be dumping these very shortly for a set of Goodyear Wrangler Durtracs.
Offline keith
  • 1176
Re: Maxxis Tires
« Reply #8 on: September 14, 2012, 05:45:30 AM »
I have the Duratracs on my Wrangler.  They ride smooth but are a bit noisy when rolling slowly such as starting or stopping.  I loose about 2 mpg with them over the stock tires.  I switch back and forth and always notice the reduction in mpg with them.
Offline built4thrashing
  • 9
  • Built by me. Built4thrashing
    • Cross Country Jeep Club,
Re: Maxxis Tires
« Reply #9 on: September 16, 2012, 04:07:02 AM »
Ive got the maxis bighorns on my gv in 245/75/16 and they are crap. The are almost worn out and have only traveled 20,000kms. I wouoldn't buy another set but if they were given to me i'd use them.
as for noise they are quiet compared to the Xtremes.
My next tyres will be either KM2's or Cooper STT's
Driven like its a rental.
Offline max-zr2
  • 45
Re: Maxxis Tires
« Reply #10 on: September 16, 2012, 12:54:05 PM »
Decided on General Grabber AT2's,    found a set of 30's online for $120/ per and free shipping.... just couldn't say no :D
Installed:
Installing:
- 2" BL
Offline talonxracer
  • 1284
Re: Maxxis Tires
« Reply #11 on: September 17, 2012, 09:38:47 AM »
Just a FYI, not all Grabber AT2's are created equal, 2 different rubber compounds are used, the harder compound does not recieve a snow rating even though they can be studded.
Offline bush buster
  • 263
Re: Maxxis Tires
« Reply #12 on: September 17, 2012, 11:47:46 AM »
Are you gonna get them studded Max?  If so we'll be taking your truck ice fishing this year!
