Yeah I'm not worried about replacing the seal, I'm worried about the diff being worn. If your seal has leaked in the past try this: grab the axle on the passenger side right where it goes into the diff, try and move it back and forth, any slop? mine has a bit and that is what the dealer was talking about when they said they have rebuilt a number of diffs. Anyway, as it turns out I had a mechanic look at it and he said mine seems fine, he thinks the diffs are being rebuilt because the worn seal causes the diff to run low on oil of which mine is not (and according to him my slop/play isn't that much = I'm a bit paranoid). He also said my seal is still OK as it is only "seeping" and not leaking (IE no oil has leaked to the bottom of the diff and it's not even wet oil)
