v6 & l4 diff
  • 8 Replies
  • 1681 Views
Offline MBB77
  • 50
v6 & l4 diff
« on: January 12, 2009, 12:19:19 PM »
what is the different between v6 differential and l4 differential?
grand vitara 03 V6
koni suspensions
king springs
one inch rubber over king
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: v6 & l4 diff
« Reply #1 on: January 12, 2009, 12:23:43 PM »
As long as you only mean within generations, just gear ratios.  V6 trucks did come with both aluminum and steel front housings while the l4s only got aluminum, but they're interchangeable.
XL-7 front coils
1.5" rear coil spacers
Offline MBB77
  • 50
Re: v6 & l4 diff
« Reply #2 on: January 17, 2009, 10:13:00 AM »
are they the same ratio
grand vitara 03 V6
koni suspensions
king springs
Offline IanL
  • 466
Re: v6 & l4 diff
« Reply #3 on: January 18, 2009, 02:05:55 AM »
Offline MBB77
  • 50
Re: v6 & l4 diff
« Reply #4 on: January 18, 2009, 10:12:41 AM »
i saw the numbers but i couldn'tunderstand them
but
i want to get more turque from my V6 manual
grand vitara 03 V6
koni suspensions
king springs
Offline IanL
  • 466
Re: v6 & l4 diff
« Reply #5 on: January 19, 2009, 02:06:13 AM »
The larger the number, the greater the reduction from crankshaft revs to wheel revs.  The greater the reduction, the more the torque.  BUT you trade torque for rpm.  In other words, if you employ more reduction, you run the engine at higher revs for the same road speed.  Your top speed, engine wear and fuel consumption all suffer.
Re: v6 & l4 diff
« Reply #6 on: January 19, 2009, 09:25:44 AM »
Fab in a Toy Previa Supercharger
Re: v6 & l4 diff
« Reply #7 on: January 19, 2009, 03:09:09 PM »
but
In what application? For off-road, for example, switch your transfer case to low range.
Offline MBB77
  • 50
Re: v6 & l4 diff
« Reply #8 on: February 01, 2009, 04:49:26 AM »
i tried every thing
but
I'd like try a diff that can give me more torque
grand vitara 03 V6
koni suspensions
king springs
