Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005
(Moderator:
ebewley
Parking Brake Indicator
jSager
37
January 21, 2006, 10:02:49 AM »
My 99 GV’s parking brake light (on the instrument panel) will continually light up, even if the parking brake is off. I’m pretty sure it’s a short, as over Thanksgiving it would flicker on during left turns and then off on right. Now it’s solid. I’ve disassembled the console and looked at the switch at the parking brake handle, and there isn’t anything obviously wrong.
Any clues?
jSager
AJMBLAZER
2166
Your mom.
Re: Parking Brake Indicator
January 21, 2006, 02:30:23 PM »
Does it say brake or parking brake on the dash? Can't say I've ever seen ours. On some vehicles the brake light will come on when you need to add a little brake fluid to the resevoir. A few weeks ago the wife mentions that said light has been coming on when she goes around corners...
"kinda hard"
...so I looked at it and sure enough, it was low. Although I have to say, the brake fluid wasn't that low, just low. I added maybe 1/8 of a pint and so far so good. She hasn't seen it since.
jSager
37
January 21, 2006, 04:39:46 PM »
It just says "Brake" and normally it would come on when I had the parking brake set. I'll check the fluid though.
jSager
jSager
37
Reply #3 on:
January 23, 2006, 06:24:37 PM »
Thank you, thank you, thank you.
I was pretty low in brake fluid, filled it up and the light goes right out.
It's nice to have a community like this with helpful people for things like this.
Thanks again,
jSager
AJMBLAZER
2166
Your mom.
Reply #4 on:
January 23, 2006, 07:14:47 PM »
No problem man. The simplest things are often the easiest solutions. Also the cheapest...
blacknight
987
Reply #5 on:
January 25, 2006, 01:10:17 PM »
If it was that low you may want to check your brake pads also.
George
