Wheel backspacing on GV's
  • 8 Replies
  • 1725 Views
Offline AJMBLAZER
  • 2166
  • Your mom.
« on: September 04, 2005, 11:36:50 AM »
What's the backspacing on Grand Vitara 16" alloy rims?
If I was to get a set of 16x7 steel rims for the GV, what would be the ideal backspacing?  We're planning a 1.5" JDMCRX lift with 225/75R16 mud tires on these rims.
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
Re: Wheel backspacing on GV's
« Reply #1 on: September 04, 2005, 12:57:42 PM »
I can measure my dads XL7 tomorrow i think there like +8mm offset on the 99 up GV
01 GRAND VITARA
Offline JDMCRX
  • 1110
« Reply #2 on: September 04, 2005, 01:00:05 PM »
By the way if u do 225 or 235/75R16 they wil only rub in the front on a lock to lock turn on the inner splash sheild i had a set of 235 75 R16 on factory steel wheels on my truck no spacers and they only rubbed on the front on lock to lock turns.
They rub here on the front
01 GRAND VITARA
Offline JDMCRX
  • 1110
« Reply #3 on: September 04, 2005, 01:01:21 PM »
If you do not want the noise we just cut a strip 3" high by 2" wide off the center of the splash shield and no more rub even under full articulation.
Ill try to get some shots today of full articulation
01 GRAND VITARA
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #4 on: September 04, 2005, 04:18:59 PM »
So just there on the bumper fascia where it folds in and under?  I can cut that thing off pretty fast.
Thanks, looking forward to those pictures. 8)
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #5 on: September 05, 2005, 09:19:46 AM »
So if I put on some of the Suzuki brand mud flaps on the front and rear wheel wells would they prove any problem?
Offline JDMCRX
  • 1110
« Reply #6 on: September 05, 2005, 11:29:20 AM »
Nope i had a set of big ones on mine and they did not rub u just have to notch them were the tire hits takes one min.
01 GRAND VITARA
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #7 on: September 05, 2005, 05:47:09 PM »
Just for everyone's knowledge stock backspacing on the 16x7 alloy rims fitted to a 03 GV is 4".
Measured while I was doing the oil change and tire rotation today. 8)
Offline ngrover
  • 131
« Reply #8 on: October 24, 2006, 09:14:31 PM »
What is the back spacing on the Grand Vitara Steel wheels? I was under the impression it was 3.75 inches but can someone verify this? Thanks.
2000 Suzuki Grand Vitara, 5spd. 2.5 inch lift, 225/75R16 AT's
