« on: February 01, 2017, 06:12:54 PM »
What are you V6 GV guys doing when making the hybrid CV as described on the main page tech article:
Now, the Passenger side:
Compare the two CV stubs. Notice that the GV is shorter than the Kick. The difference in the two side lengths is because the air diff moves the centerline over about 1″ towards the passenger side.
What you want to do here is swap the Kick stub onto the longer GV mid-shaft and outer CV.
1. Carefully cut the band around the CV boot.
2. Remove the GV’s stub/ CV cup and replace it with the stub/cup off the Kick, making a “hybrid” CV shaft. Use the new clamps on the boot.
On my XL7, which I think uses the same CV's as a V6 GV, the Sidekick stub is smaller than the GV one, so they are not interchangeable. Just wondering if any GV owners ran into this and what they did.
01 Vitara 2.0L 5 speed, 2.5" Calmini lift, 2" body lift, Sidekick rims, locked rear, 31's, 4:1 low, 5.13 diffs <SOLD>
