Do it yourself bedliner stuff on plastic??????
  • 12 Replies
  • 2458 Views
Offline atc_gv
  • 76
« on: November 21, 2006, 09:36:31 PM »
Has anyone used the do it yourself bedliner on plastic trim? I was thinking of using durabak on my trim because I had to replace a part of the trim because it broke off. The trim comes in plain black plastic. The customer service people at durabak said in most cases it should adhere. I don't want to be the case that doesn't work. Any other solutions to painting the trim out there? Maybe some bumper paint or something......Thanks
Offline sklope
  • 135
  • BUSHWACKER
Re: Do it yourself bedliner stuff on plastic??????
« Reply #1 on: November 21, 2006, 09:42:09 PM »
I was missing the two pieces of side trim on the front quarter panel of my tracker. This is the door bumpers that keep you from getting dings on the side of your vehicle. I used Krylon plastic paint and it has held up well with two coats. I have even had some a**hole bump the side with his door and it did not chip the paint.
* '96 Tracker
* 2" Sky body lift
* 235/75/15 M/T's
* Custom front and back bumpers
* Durabak exterior coating (bed liner) * '07 chevy silverado "wail tail" tailgate cover (custom cut to fit)
Offline atc_gv
  • 76
« Reply #2 on: November 21, 2006, 09:45:25 PM »
Is that the platic paint for bumpers??Has anyone used the bumper paint?
Offline AZMIKE
  • 6
« Reply #3 on: November 29, 2006, 08:08:53 PM »
use the durabak it will work. i did the exterior of my sami with durabak. of course i got a little sloppy and got it all over. i can tell you that it sticks to..... weatherstripping, the rubber thing that keeps the door from swingin out to far, seat belts and the roll bar padding. im sure it will stick to plastic.
87 SAMIURAI
Offline atc_gv
  • 76
« Reply #4 on: November 29, 2006, 10:03:15 PM »
Cool man thanks I was just waiting to see if someone used it before I got it. I post pics when done.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #5 on: December 02, 2006, 06:59:33 AM »
Considered just taking the trim off?  That's my next step.  All of the trim and flares are coming off and then everything that had it is getting Rhino Lined.
I Herculined my Tracker but I think for the GV I'll pay extra for a smooth Rhino Liner that's thicker.
Offline atc_gv
  • 76
« Reply #6 on: December 02, 2006, 10:21:08 AM »
I thought of that but it seems like it would be alot of work to fill all those holes and cut off the metal part that holds the fender flares on.
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« Reply #7 on: December 02, 2006, 12:09:28 PM »
I tried spraycan bed liner on plastic trims a couple of year ago.
Sand the surface and shoot it!
They work great for me.
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #8 on: December 02, 2006, 05:29:40 PM »
Metal part that holds the fender flares on?  I haven't seen that myself...is there a rail or something under there?  I doubt they'd do anything other than cut a hole in the body on the GV's and XL7's.
What I did on my Tracker was after it was all cleaned up and ready for the bedliner I put little squares of duct tape over the holes in the rockers for the fascia and then bedliner'd right over those.  So far, so good.  I can't even tell where the holes are even with Herculiner.  With Rhino Liner or Line-X it'd be even harder to tell.  I got this idea from 4-Wheel & Off-Road's Project TrailLex a few years back.
Offline atc_gv
  • 76
« Reply #9 on: December 02, 2006, 09:51:12 PM »
At least on the rear wheel well there is an inch of a metal lip. The top fender flare covers it up.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #10 on: December 02, 2006, 10:18:50 PM »
If it's like the metal track they used on the Trackers it can be removed.
Offline atc_gv
  • 76
« Reply #11 on: December 04, 2006, 11:37:12 AM »
Do I just pry it off?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #12 on: December 04, 2006, 07:53:52 PM »
Errmmmmmmm.......damn, it's 20 degrees F and my service manual is out in the garage...
On the older Trackers/Sidekicks the fascia track thing is held on by plastic clips that have screws in them to force them out into the holes.  I'm thinking Suzuki would have used something similar on the next generation...but I could be wrong.
Have you had it apart and seen the actual track dohickey?
