Ring and pinion options for a 1999 chevy tracker?
  • 2159 Views
Offline 3D
« on: September 05, 2012, 08:39:39 AM »
Hey guys new on here. I've run alot of early model trackers but never the 99 and up. Is there any aftermarket support for ring and pinions? Or will any of the older ring and pinions interchange ?
  • 4314
  • 167
Re: Ring and pinion options for a 1999 chevy tracker?
« Reply #1 on: September 05, 2012, 10:20:32 AM »
I haven't tried it personally, but I understand they do, although you might need to swap the entire third member, and the fronts may give some trouble with axle lengths - at least, ARB says if you to put an air locker into the later models, you have to swap in a third from an earlier model.
There's also a turkish firm who have advertised a 5.72 gear set - http://tr.4xfourart.com/4xfourarten/urunic.php?id=65
Offline 3stagevtec
  • 204
  • killing two stones with one bird...
« Reply #2 on: September 07, 2012, 08:51:34 AM »
I'd so love to get my hands on that 5.72 gear set! Who wants to be the guinea pig??
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #3 on: September 07, 2012, 12:38:20 PM »
I should have taken more time measuring the front ring gear of the 2002 tracker while it was out to see what kind of difference in thickness it had in comparison with the 1st gen front gears.
The 2nd gen Trackers came with 4.62 in the 4-door 5spd models, 4.88s in the autos AND 5.12s in the 1999 and 2000 2-door models that came from the factory with the 1.6 liter engines.  Not many of them produced, but I'd sure like to find a pair of gears from one.  Direct bolt in without having to screw with changing CV lengths.
For a 5spd equipped 4 door truck that would provide some serious increase in mechanical advantage and would probably put you back to near stock mechanical advantage while running 31" tires.  It would be even "more better" if a pair of 5.38 gears would installed.
« Last Edit: September 09, 2012, 02:22:08 PM by nprecon »
