still havent found a gas tank :(
  • 8 Replies
  • 1289 Views
Offline diftoyota
  • 253
« on: July 10, 2012, 06:40:17 PM »
well its been since febuary that im looking for a replacement gas tank for my vitara, i am lucky enough that the little leak i had on the very bottom was temporary fixed with my jb weld job, i've made sure it was dry then sanded the area, then cleaned the area with brake cleaner. it is still holding up. but the question is for how long
does anybody know were to buy a brand new tank? the dealership at chevrolet told me 1500$ with no sending unit and i have to get my name on a list, wen the list is big enough they will make a batch. dosent sound good to me, suzuki price was a bit under 600$ but same story as chevrolet
Offline FireCkrEd
  • 246
    • My Church-San Pedro Revival Fellowship
Re: still havent found a gas tank :(
« Reply #1 on: July 11, 2012, 05:32:01 AM »
If you can remove the tank when empty why can't you weld the hole shut ?
93 4dr Kick, stock, + 95 4dr W/TTough kit, Toy axles, 4.24 xfercase gears, 5.71 gears, Ramsey 9500 winch, twin stick xfercase, 33" BFG's
97, 4dr with a 2" lift (needs an engine re-build)
Spirit Filled Christian
Offline diftoyota
  • 253
« Reply #2 on: July 11, 2012, 07:14:58 AM »
BOOM !! i hate welding on gas tanks, and i know there is a few other soft spot under it, too much work to save it
  • 4319
  • 167
« Reply #3 on: July 11, 2012, 10:04:36 AM »
Google sloshing sealant - it might do what you need.
Offline xjnewfie
  • 41
« Reply #4 on: July 11, 2012, 10:37:08 AM »
Where are you located?
I just blew my front diff, and replaced my rig with a 2006 TJ.  About 2 years ago I had my tank professionally resealed, and it now has a life time warranty.  Not sure what the cost of shipping would be, or how much I'd want for the tank just yet (may sell the whole rig instead of parting it out), but I figure it don't hurt to look into this if it helps out fellow Zuki lover.
My rig is a 2003 Vitara, 4 cylinder.  I believe the tank is different on the 6 cylinder models.
2003 4 Door Suzuki Vitara
2" Coil Spacer lift
245/75R16  BFG A/T
« Reply #5 on: July 11, 2012, 03:59:48 PM »
i also have a spare tank
located in Ontario, Canada (not sure where your from)
20min east of toronto
Offline diftoyota
  • 253
« Reply #6 on: July 13, 2012, 06:24:23 PM »
im in rogersville new-brunswick, there is two tanks for 4cy vitara's a 5 hole and a 4 hole tank, i need the 5 hole or 5 opening one,
Offline xjnewfie
  • 41
« Reply #7 on: July 15, 2012, 08:03:54 AM »
Is there an easy way to determine which tank I have?
2" Coil Spacer lift
245/75R16  BFG A/T
Offline diftoyota
  • 253
« Reply #8 on: July 16, 2012, 07:18:10 PM »
not that i am aware of yet, havent seen an 4 hole one to tell a diference
