Modification to question;
Has anyone installed " Jeff's" spacer/shock & strut extension kit on to a Zuki GV ?
Are 01' Chevy-Trackers the same as 01' Zuki GV's, Because he will only state that his kits have only been installed onto Trackers of about the same year.
Hi All ; New Member here with Zuki Lift question.
I own a 2001 Zuki GV , & have already had a " 2" body lift " from " won't mention manufacturer" that was advertised to fit ( sidekick, tracker, vitara & grand vitara ) most everything in kit worked fine a few parts had to be fab'd, but overall everthing worked out OK. NOW I'm looking to put a 1-3/4", 2" suspension lift ( spacers & extentions ) " & this kit will be from a different " won't mention manufacturer " that is advertised for ( SUZUKI SIDEKICK GEO TRACKER - XL7 ) .
My question on this forum is " what experiences have any of you had with "spacer suspension lifts" ?? Are they all mostly the same " always needing some sort of part fab'd " or is there 1 or 2 "manufacturers " that are better then most all the others ??
Oh & I need to mention I'm on a very limited budget.
Thank you all in advance,
AZrider01
