2 inch rocky road body lift on GV's and vits
  • 52 Replies
  • 5583 Views
Offline bzzr2
  • 1011
Re: 2 inch rocky road body lift on GV's and vits
« Reply #45 on: July 24, 2006, 06:43:21 AM »
if i put 32's they would be rubbing without question, probably a lot. i saw what you would like to do with your's.  maybe a 1/2 inch spacer in front and a 1inch in the rear, remove all the plastic parts.. and you might get them in there, i'd stick with max 10.5 wide.  i'm sure you could stretcch your body lift up 1/2 inch without worrying about changing anything else.  evertying seems like a lot of work for small results at this point lift wise.  good luck!
09 taco reg cab short box 4x4
Offline ZR2
  • 103
  • Powered by SUZUKI
    • See the best sidekick/tracker/vitara website!!!
« Reply #46 on: July 24, 2006, 08:18:39 AM »
So i can fit 32" easily with 2.5" of suspension modifie at 3" and 3" of bodylift with wheelspacer of 1.25" and remove all the plastic...???
Offline bzzr2
  • 1011
« Reply #47 on: July 24, 2006, 10:09:38 AM »
i think it would be very close, remember if you put a 0.5in coil spacer in the front you will get a bit more, say .75inch of lift in the front, that's why i suggest 1inch for the rear.  you may need driveline spacer for that too, not sure?  i also don't know how much extending things will be involved iwith adding an extra inch to your body lift.  i don't want to say yes you will be able to fit but i'm willing to bet it would be close with all the plastic removed.  also depends which 32's you go with because of the actual size differences.  bonne chance, et j'espere que ca marche pour toi, eventuellement c'est ca que j'aimerais faire avec mon tracker aussi!
where did you get your wheel spacers?
« Last Edit: July 24, 2006, 07:41:36 PM by bzzr2 »
Offline ZR2
  • 103
  • Powered by SUZUKI
« Reply #48 on: July 25, 2006, 06:44:37 AM »
i get my wheelspacer at local store! so y need to machine it to fit on my truck!
Offline bzzr2
  • 1011
« Reply #49 on: July 25, 2006, 06:49:44 AM »
ok thanks, i'll have to start shopping soon..
Offline blacknight
  • 987
    • Gonzookin
« Reply #50 on: July 25, 2006, 11:14:47 AM »
spidertrex has them cut to fit the GV
http://www.spidertrax.com/s.nl/sc.2/category.17/.f
Geogre
Offline hap
  • 38
  • huh?
« Reply #51 on: July 25, 2006, 12:27:21 PM »
Be careful with spidertrax as the set I ordered did not fit without modification. They also don't seem to want to respond to you once they have your money.
Offline bzzr2
  • 1011
« Reply #52 on: July 26, 2006, 06:29:33 AM »
good to know, thanks.
