change 16" wheels to 15"?
  • 827 Views
Offline mfoster442
  • 29
« on: August 19, 2009, 05:31:32 PM »
Greetings Everyone.
I have a 2002 Vitara 2.0L with 16" steel wheels running 235/70R16s.  There's not as many tire choices for the 16" rims in that size range.  Can I put 15" wheels on my rig?
Thanks.
2002 Vitara
235/70/R16 Cooper Discoverer S/Ts
Stock engine and running gear
Boondox Spacers
Pro-Comp Shocks Strut extenders Camber bolts
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: change 16" wheels to 15"?
« Reply #1 on: August 19, 2009, 08:51:45 PM »
I'd trial fit the 15" rim your considering on the front of your truck first .  If you can snug it up and spin the wheel you should be good to go.  However, if your truck has the larger calipers 15" factory wheels (Tracker/Kick) won't clear the larger calipers.
Offline olija
  • 770
    • Check out my cardomain
« Reply #2 on: August 20, 2009, 10:40:09 PM »
If you get some 15" steel wheels from a Sidekick they will work. I have the "bullet-hole" variety on my 01 Vitara 2.0L and they fit, no problems.
