you could also slot the lower strut holes making more room for adjustment, i've heard guys have had to to this a bit even with camber bolts, if you have a true increase in front of 3inches you might be slotting either way.
I'm not really in favour of "slotted" strut holes - I've had problems with the camber changing because it's impossible to tighten the bolts down enough to hold - I have seen some guys use large washers on the outside of the struts and after completeing alignment, tack welding the washers to the strut to hold things in one place.
