Boondox coil spacers for GV's
  • 1295 Views
Offline the_maplebar
  • 466
« on: July 19, 2006, 08:22:28 AM »
I have noticed that Boondox has different coil spacers specifically for the GV's and was wondering how they fit?  I know some of you have purchased and installed them already, so let's hear about them.
http://www.boondoxmotorsports.com/zuk_suspension.html
I can tell you that Josh's (JDMCRX) coil spacer's fit great.  They were easy to get on, but tight enough that they stayed in place on their own while I was positioning the rubber isolater and spring.
I would also be interested to know if anyone has experience using Sidekick coil spacers.  Do they fit fine, is there even a need for coil spacers made specifically for the GV or are they the same thing?
Offline lowrezolution
  • 292
  • "Get bent!"
Re: Boondox coil spacers for GV's
« Reply #1 on: July 21, 2006, 05:11:12 PM »
Mine fit excellent, the only issue was the front would have sat higher if I hadn't added an extra spacer between the boondox one and the spring mount.
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
Offline Autobot
  • 189
  • Danger Can Happen!
« Reply #2 on: July 28, 2006, 07:31:29 AM »
What size spacer did you fit to level out the back, and where did you get it from? If you didn't would there be a noticable difference between the front and back? I was looking at the BD spacers as well. For $100 it seems like a good price.
Got Tracker?
2000 2dr. convertible, stock.
Offline bzzr2
  • 1011
« Reply #3 on: July 28, 2006, 10:22:06 AM »
i have a 1 inch spacer in front and a 1.5 inch spacer in the rear of my tracker and it sits well.  if you did order the boondox spacers you could either trim 2 of them down for the front a bit and maybe add an extra spring isolator or 2 to help keep the rear up.
09 taco reg cab short box 4x4
