Are you supposed to remove the sway bar?
  • 8 Replies
  • 3953 Views
Offline lowrezolution
  • 292
  • "Get bent!"
« on: April 29, 2006, 01:28:30 PM »
Am I supposed to remove the front swap bar after installing the lift?  ???
The link ends where really hard to get into the mounting holes and they are now on a strange angle.
Could this be part of the camber problem?  ???
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
  • 292
  • "Get bent!"
Re: Are you supposed to remove the sway bar?
« Reply #1 on: April 30, 2006, 12:16:56 PM »
Somebody, anybody??????? ??? ???
2001 Tracker LWB
Offline 2K1USGV
  • 218
« Reply #2 on: April 30, 2006, 02:53:21 PM »
You need to reinstall it with all wheels on the ground. I would install everything drive the truck back and forth a couple of feet so the suspension settles and than reinstall it.
  • 292
  • "Get bent!"
« Reply #3 on: April 30, 2006, 03:26:56 PM »
I've seen a few people saying they removed their sway bar, what advantages/disadvantages come along with removing it? Does it help articulation but sacrafice on road handling?  ???
2001 Tracker LWB
Offline Shredder
  • 389
  • She thinks my Tracker's sexy
    • Me & My Rig
« Reply #4 on: April 30, 2006, 05:12:40 PM »
Sway bar? What's that? J/K Anyway, I removed mine and I noticed better articulation off-road but it feels the same on-road as it did before. I couldn't even tell it was gone. BTW- I drive mine pretty aggressive on all the winding roads around here. Just ask DWiddowmaker he had to follow me yesturday down some of them.  ;D
'96 Astro Van 2wd, +10 Overland, 32s, Tow Rig
'96 Tracker LWB 4x4, +4.5 Calmini/Boondox, +3 Boondox BL, 31x10.50 (wife rolled)
'93 Sidekick LWB 2x4, 235s, +3 Boondox Suspension kit, 4wd swap 2b
'91 Tracker SWB, Toy axles, YJ Springs, Boondox Swap Kit, 31x10.50
« Reply #5 on: April 30, 2006, 06:26:30 PM »
Took mine off. I think it rides much softer with out it.
Maybe a weee bit of extra lean into corners
plus. The IFS will flex better without it anyways.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #6 on: May 01, 2006, 04:27:16 PM »
What he said.  I don't own a vehicle with a swaybar.  We took the swaybar off the GV a while ago and my wife's only comment was that it rode better.  That's been my experience with every 4x4 that I've done this too so far.
Personally I think sway bars are there for legal reasons more than actual technical reasons when it comes to OEM 4x4 trucks.
  • 292
  • "Get bent!"
« Reply #7 on: May 01, 2006, 05:26:57 PM »
Thanks for the replies guys, I'm glad you all said to turf it , cause I already did !!!   ;D :P ;D
Just needed some back-up as my brother-in-law works at a GM dealer and got all bent about the idea of removing it.
Thanks again, EH! :)
2001 Tracker LWB
Offline sergi
  • 307
« Reply #8 on: May 02, 2006, 02:16:12 PM »
I removed my sway bar too,a long time ago. Off road articulation was a little better, the rear wheels took longer to leave the ground (because now the front articulates a little more).
On road, it leans a little more if you brake in the middle of a curve, but you're actually supposed to accelerate when in a curve, so no problem! ;D
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
