I've got an update on the OME stuff and my lift. Here's my experience thus far on my '01 2-door.
Lift: 2" Coil Spacers from Jeff. Please correct me if I'm wrong Jeff, but I remembered you saying that the front spacers provide just over 2" of lift to level the car. I actually wanted just under 2" for what I was trying to accomplish so I did some math and took off 3/16" from the front spacers. The height turned out perfect.
Rear OME N32 (2-door specific) Shocks from Low Range Off Road: They have about 1.5" more down travel than the stock shocks. The diameter of the body of the shock is significantly larger than the stock shocks so this caused an interference with the lower shock mounts. Due to tolerances, I had to trim 1/8" off the passenger side shock mount and 1/4" off the driver side to keep the shock body from hitting the mount during the suspension travel. I wasn't happy about doing this but I was committed by the point I realized what was happening. They come with new bushings, hardware, and a metal "dust cover" for the piston. Once on the car, they ride nice.
Front OME Struts from Low Range Off Road: They have almost 2" more down travel than the stock struts which translates to about 3" at the wheel - I was impressed with how much better this looked. They do NOT compensate with respect to your camber though for a 2" lift. In order to align it you will need camber bolts or need to elongate the strut holes. The struts do not come with new rubber bushings for the top so you will need to re-use your old ones or you can order new ones from rockauto or something. They do come with a new nylock nut for the top though. The struts do not come with a "dust cover" for the piston. I took the plastic covers off my factory struts and swapped them on. Like the rears, the front struts also ride nice.
I can't compare my set up above to others but it was more work than I expected to get everything tweaked just right. I initially installed the front sway bar, but it didn't line up well with the new angle of the lower control arms with the lift. It would have eaten sway bar end links fast. I drove about 100 miles with it on and now have it off. There is a difference with it off, but it is barely noticeable with the new struts. I'm keeping it off for now.
Vendor experience were great. Jeff took my order and got me parts fast. Same for Low Range Off Road. The shocks/struts/lift were just a part of what I was doing on the car so I also ordered stuff from Trail Tough (shift on the fly removal stuff), Rocky Road (greasable u-joints), Rock Auto (tons of misc), and gmpartsonline.net (whatever I couldn't get from rock auto) with good success.
