Anyone on Old man EMU kit?
  • 24 Replies
  • 3091 Views
Offline ATW_SGP
  • 20
« on: October 07, 2010, 03:09:16 PM »
Hello,
I have a 2004 Suzuki Grand Vitara 4 door auto..
Was wondering if there's anyone that runs the complete rocky road 2" body lift kit with Old man Emu springs and absorbers?
Would love to hear your feedback as i am considering to change to them
Rgds
ATW
Singapore
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: Anyone on Old man EMU kit?
« Reply #1 on: October 11, 2010, 03:19:24 PM »
I only ran the OME springs (with strut extenders).  The ride was noticeably "more plush" compared to the standard springs with coil spacers.  I do not have a body lift.  If there were some type of warranty on the OME struts (like a year parts or some variable) I'd jump on a pair.  But to my knowledge there isn't so I'm staying with the factory Monroe or Gabriel replacement struts.  You still have the labor/time of installing them but when they blow early you are at least covered for the part.
Offline Frank84
  • 176
« Reply #2 on: October 11, 2010, 04:33:30 PM »
The last set of OME shocks I bought had a two year warranty.
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
Offline nprecon
  • 2318
  • 52
« Reply #3 on: October 12, 2010, 10:17:59 AM »
What about their struts?
Offline Frank84
  • 176
« Reply #4 on: October 12, 2010, 04:27:21 PM »
The shocks I had were for a land rover so I can't comment on their strut warranty yet.  However, I just ordered OME shocks and struts for the Tracker yesterday so I will let you know next week when they arrive.
As for OME reliability - I have mixed feelings.  I just replaced a set of OME shocks on a Discovery that had about 150k miles on them with a new set of the same OME shocks and could barely tell a difference.  The old ones were still good and didn't need replacing I guess (my dad's truck).  However, the OME steering damper on the same car started leaking after about 100k miles.
I have an old range rover with OME shocks and had to replace one about two years ago that blew out. But that truck gets some very heavy abuse off road.  I'll probably go with Bilsteins or something on this truck next time I replace them all as a set but I do like the way the OME's ride.
If there were more choices for the suzuki's I'd probably have ordered something other than OME's to be honest.  I just thought that they were the best for me of what was available.  The struts have extra down travel and correct the camber for a small lift (I'm trimming Jeff's spacers to give a 1.5" lift).  My Tracker doesn't get too much abuse so hopefully they will last like they did on the Discovery.
My friend ordered the Doetech (or something) shocks from rocky road for his Cherokee and the bushings split after 100 miles.  Rocky road was nice and sent new bushings right away but the new ones did the same thing.  Ordered some poly ones and everything has been fine for 10k miles at least.  I didn't want to deal with this.
Offline nprecon
  • 2318
  • 52
« Reply #5 on: October 12, 2010, 10:33:27 PM »
Good info Frank84.  Thank you much!!!
Norm
Offline ATW_SGP
  • 20
« Reply #6 on: October 16, 2010, 12:19:10 PM »
Great info.. thanks!! it's helpful.
How about.. Ironman Australia?
Rgds!
Offline Frank84
  • 176
« Reply #7 on: October 20, 2010, 02:18:23 PM »
by the way, warranty on old man emu suspension parts is 2 years 24k miles.  I'm not sure how they check the mileage but I guess two years can be proved with a receipt from purchase.  This at least gives me some confidence with the new parts I bought.
Offline nprecon
  • 2318
  • 52
« Reply #8 on: October 25, 2010, 05:32:37 PM »
That appears to be a fair and reasonable warranty to me.
Offline Frank84
  • 176
« Reply #9 on: November 16, 2010, 02:21:44 PM »
I've got an update on the OME stuff and my lift.  Here's my experience thus far on my '01 2-door.
Lift: 2" Coil Spacers from Jeff.  Please correct me if I'm wrong Jeff, but I remembered you saying that the front spacers provide just over 2" of lift to level the car.  I actually wanted just under 2" for what I was trying to accomplish so I did some math and took off 3/16" from the front spacers.  The height turned out perfect.
Rear OME N32 (2-door specific) Shocks from Low Range Off Road:  They have about 1.5" more down travel than the stock shocks.  The diameter of the body of the shock is significantly larger than the stock shocks so this caused an interference with the lower shock mounts. Due to tolerances, I had to trim 1/8" off the passenger side shock mount and 1/4" off the driver side to keep the shock body from hitting the mount during the suspension travel.  I wasn't happy about doing this but I was committed by the point I realized what was happening.  They come with new bushings, hardware, and a metal "dust cover" for the piston.  Once on the car, they ride nice.
Front OME Struts from Low Range Off Road: They have almost 2" more down travel than the stock struts which translates to about 3" at the wheel - I was impressed with how much better this looked.  They do NOT compensate with respect to your camber though for a 2" lift.  In order to align it you will need camber bolts or need to elongate the strut holes.  The struts do not come with new rubber bushings for the top so you will need to re-use your old ones or you can order new ones from rockauto or something.  They do come with a new nylock nut for the top though.  The struts do not come with a "dust cover" for the piston.  I took the plastic covers off my factory struts and swapped them on.  Like the rears, the front struts also ride nice.
I can't compare my set up above to others but it was more work than I expected to get everything tweaked just right.  I initially installed the front sway bar, but it didn't line up well with the new angle of the lower control arms with the lift.  It would have eaten sway bar end links fast.  I drove about 100 miles with it on and now have it off.  There is a difference with it off, but it is barely noticeable with the new struts.  I'm keeping it off for now.
Vendor experience were great.  Jeff took my order and got me parts fast. Same for Low Range Off Road.  The shocks/struts/lift were just a part of what I was doing on the car so I also ordered stuff from Trail Tough (shift on the fly removal stuff), Rocky Road (greasable u-joints), Rock Auto (tons of misc), and gmpartsonline.net (whatever I couldn't get from rock auto) with good success.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #10 on: November 16, 2010, 03:21:37 PM »
Did you do anything regarding bumpstops?
Also, I don't suppose you have any photos of the trimming work to clear the shocks?
« Last Edit: November 16, 2010, 03:23:08 PM by beercheck »
XL-7 front coils
1.5" rear coil spacers
Offline Frank84
  • 176
« Reply #11 on: November 16, 2010, 04:19:34 PM »
I left the bumpstops alone.  I haven't really flexed it out yet or used it off road so I can't tell if I'll need to do anything at all to them.  I only have 215/75/15 tires so there aren't any rubbing issues to worry about.
I don't have any pictures of the shock mount trimming but I will take some next time I'm home and the sun is up at the same time.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #12 on: November 17, 2010, 07:38:18 AM »
Yeah, this early darkness stuff sucks.
Thanks for your updates.  I've finally, at long last, gotten around to removing the squished-to-about-1/4" that used to be 1" RRO spring spacers and installed 2" in the rear.  Am about to order the N32 shocks, and your comment is the first I've seen that mentions having to do any grinding.  It's good intel:  I'd hate to budget only the usual 45 minutes for a shock absorber change, then realize in the middle that I've got another hour+ of compressor retrieving, grinder wheel finding, and actual grinding to do.  It gets dark early these days, and cold!
XL-7 front coils
Offline bzzr2
  • 1011
« Reply #13 on: November 17, 2010, 01:50:34 PM »
skip the expensive shocks, i run 80's model tbirds out back, trust me on this, i've tried crown vics, mustangs, cavaliers and now these, longer beefier and mount perfectly to your truck.
09 taco reg cab short box 4x4
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #14 on: November 17, 2010, 03:41:00 PM »
Do those have a nice exposed shaft that, say, Daystar's EVS bump stops might fit onto?
http://www.daystarweb.com/productdetail.php?productID=679
XL-7 front coils
