Air pressure
  • 13 Replies
  • 2710 Views
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
Air pressure
« on: March 14, 2009, 07:12:01 AM »
What air pressure are you guys running on-road in :
225/75R15 = ?
235/75R15 = ?
30 inch         = ?
32 inch         = ?
Thanks.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Air pressure
« Reply #1 on: March 14, 2009, 07:47:56 AM »
I run my 30" BFG AT/KOs at 35 pounds.  It tends to make the ride a bit harsh, but the mileage is good and the wear across the width of the tire is even.  This is on a 1.6 Samurai that is not overly modded... maybe 2350-2450 lbs curb weight.
« Last Edit: March 14, 2009, 07:50:24 AM by ack »
Ack
Offline 97TRAKIN
  • 600
Re: Air pressure
« Reply #2 on: March 14, 2009, 09:07:36 AM »
Thanks for the response it contained helpfull info such as pressure, size, tire wear, and ride comfort.
Any more out there?
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: Air pressure
« Reply #3 on: March 14, 2009, 10:30:32 AM »
I have 235/75/15s and I had been running them at 34, for better mileage but like ack said, it makes for a harsher ride.  I just went down to 32 pounds and am going to try that for a while. Mother and father inlaw have a ZR2 (with factory 215/75/15s) and she was complaining about the rough ride so I took them down to 28 pounds (which I beleive is the factory specs) and she likes the ride much better.
Offline 97TRAKIN
  • 600
Re: Air pressure
« Reply #4 on: March 14, 2009, 11:18:42 AM »
Factory on 4 door ZR2 I think is 26psi. The same as the other Trackers, LT and so fourth with 215/70/R15.
Offline 2K1USGV
  • 218
Re: Air pressure
« Reply #5 on: March 14, 2009, 01:55:32 PM »
265/70/16 (~31"s) running as 31psi as I wanted a more comfy ride and didn't care about the 1 or 2 MPG's I'd save at running them at 35psi.
Offline TopHeavy96
  • 488
Re: Air pressure
« Reply #6 on: March 14, 2009, 02:36:33 PM »
'96 4-door, stock weight, 30x9.5 BFG m/t, 35 pounds of air to (hopefully) minimize cupping :-\, rides stiffer than stock, but not bad.
Offline rascott
  • 669
  • 15
Re: Air pressure
« Reply #7 on: March 14, 2009, 10:29:13 PM »
i have michelin lx light truck tires(31x10.5x15) on 7"rims.
heavy road tires, i run 20psi on the road, and as low as 10psi off.
no daily driving, and 55mph is about as good as it gets.
handles fine and i see no funny wear.
i removed the front stabilizer and don't miss it at all either.
i seem to get ok gas mileage and can carry enough.
Offline CG98x
  • 38
Re: Air pressure
« Reply #8 on: March 15, 2009, 04:30:37 AM »
215/85/16s been runnin about 20lbs for better traction throughout the winter they have worn even and the ride is pretty good but there is a little sway with a tire this tall and skinny with only 20 lbs in it and mileage is down maybe 1 mpg.
1999 Vitara 2.0l 5 Speed. 2 inch body and 2 inch suspension lift. 215/85/16 Capital AT's. Custom bumpers and a few other things 5.13's and no air diff.
Offline ack
  • 1659
    • Ack's FAQ
Re: Air pressure
« Reply #9 on: March 15, 2009, 01:20:17 PM »
ME TOO!
My "new" '02 ZR2 4-door sez 26 pounds on the tire placard located on the driver's door post.
BTW, this is my 4th Suzuki-based truck...  I'll be selling a '96 Tracker and a '93 Sidekick 4-door soon...  The neighbors are getting restless
Ack
Offline Novadon
  • 205
  • South Carolina. USA
Re: Air pressure
« Reply #10 on: March 16, 2009, 03:27:03 AM »
Stock tires and suspension here. 26 PSI, cold. Period.
Negligible tire wear and MUCH better ride quality than with higher pressures.  ;)
03' Honda Odyssey
Offline bzzr2
  • 1011
Re: Air pressure
« Reply #11 on: March 16, 2009, 06:57:19 AM »
old beat up 31's that seem to be soft and saggy most of the time at 30psi - 35psi if they'll hold the air..
09 taco reg cab short box 4x4
Re: Air pressure
« Reply #12 on: March 16, 2009, 09:51:08 AM »
225/75R15 = ?
235/75R15 = ?
30 inch         = ?
32 inch         = ?
Thanks.
I am '01 GV H25, stock but for BFG AT T/A ko's 215/70/16's, K&N in the air box, Magnaflow secondary cat and muffler with 2.25 inch pipe, new KYB stock struts and gas-a-justs.  (Wow, did that raise my COG!)
Stock pressure is 26 for the original Duelers.  I run 34-36 road for mileage, and even tire wear.  They are 6 ply with 3 ply sadewall.  If I get into deeper snow or a bit of mushy roadbed (no deep sand or mud, and no rock ckimbs), I can drop that to whatever is nec, but NEVER lower than 24 as the stiff tires don't do well below that, at least so far.  If I am going off road, I always take my air tank.
At 36#, the ride is harsh on many Oregon roads and highways, but the new suspension parts make it hard to determine attribution right now.  Obviously much better dampening of spring travel/compression.
I should point out that as the tires wear and stretch, the pressure issue changes somewhat with the increased flexibility.  My tires are new second set, near 45k miles on first ones.
More than you asked for.
Pat
« Last Edit: March 16, 2009, 09:54:14 AM by Roguevalleyblue »
Offline 97TRAKIN
  • 600
Re: Air pressure
« Reply #13 on: March 18, 2009, 05:44:48 PM »
Myself.
2004 Chevy Tracker 4-door, V6.
225/75/R15 |removethispart|@ 31psi. The ride is nice and firm (not uncomfortable).
Then again I don't ride in the back seat lol...
