I've read the FSM for removing the dash and it seems fairly straight forward, so I guess its coming out this weekend. What is the secret to avoid tearing your hands to shreds?
David
Good question. The secret is....DON'T FOLLOW THE FSM. Unless you've got some pages mine doesn't have, it's going to tell you how to take it apart while leaving the frame in place. That is NOT how the assembly was installed at the factory, and it WILL lead to pain.
What you want to do is take the whole thing out, including the frame. A couple bolts at the base of the windshield, a couple bolts near both front door jambs, a few bolts under the carpet on the transmission hump, a couple bolts holding up the steering column (which you CAN let hang, but propping it up with something is probably a good idea). Unplug pretty much everything from the junction block in the driver's footwell and the ECM in the passenger footwell. Also unplug the yellow airbag connectors. There may have also been a harness heading to the shifter or something, I'm a little foggy on it. Also, there's a linkage accessable from the driver's footwell that connects the AC controls to the defrost/vent/floor flapper, and another on the passenger side that connects to the heat/cold flapper.
I'm pretty sure you'll also need to borrow/rent/buy a steering wheel puller. (When reinstalling the steering wheel, pay attention to the instructions for reinstalling the clockspring/airbag/horn switch in the FSM. Piece of cake, but you don't want to screw it up.)
At that point, you'll be ready for a buddy to help you move it around to make sure you unplugged/detatched everything, and out it comes. It's not heavy, just awkward.
I may have missed something or another there, but if you just take it easy, you won't have any problems. If you have a digital camera, taking a quick pic everytime you're about to disconnect something will give you a lot of peace of mind when it's going back together.
