JayInBarrie; Have you pulled one of your A-arms and checked out the "seal deal" yet?
I check out a couple of parts stores and nothing. One guy even rumaged around and gave me a couple of boots off of spare parts.
Ended up buy the boot seal from the stealership. Didn't take many pics, I'll try and get them up later.
The old boot has a wrap around spring that holds it on, you gotta really clean the base of the boot to see it there.
The new boot ($26 from the stealship) comes with a little grease pack and wire. Instructions say not to use the old spring, but to wrapped the wire around twice and twist tight. The instructions show the boot for the tie rod end. Looks like the same boot. The tie rod end boots would be EASY to pull at a yard if actually are the same boot.
