A/C Fuse keep blowing?
  • 1005 Views
Offline Frank84
  • 176
« on: June 11, 2010, 01:52:02 PM »
FYI - I've had the A/C fuse (25 amp under the hood) keep blowing on me for the last 3 years. I've seen some other posts here and other places about this problem.  Turns out the wiring harness on the passenger side under the hood was rubbing on the strut bar and was shorting out.  Just bent the wires out of the way and added some electrical tape.  Simple fix for an annoying problem.  Hope this helps someone.
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
Offline johndb
  • 26
Re: A/C Fuse keep blowing?
« Reply #1 on: June 18, 2010, 10:11:05 AM »
A bad condenser fan will also blow your fuse.
Offline Frank84
  • 176
« Reply #2 on: June 18, 2010, 03:18:18 PM »
believe it or no, i had both problems at the same time.
