Amazing!! 33" tires with a jeff lift kit!!
  • 18 Replies
  • 2536 Views
Offline diftoyota
  • 253
Re: Amazing!! 33" tires with a jeff lift kit!!
« Reply #15 on: July 29, 2012, 09:47:33 AM »
XL7 coils are rated at a higher load rating than Vitara coils.  In fact since yours is a 4 cyl Vitara then probably a lot more.
Interesting tid bit - if I remember correctly they're actually shorter than GV coils.  The wire in the coil is thicker for more capacity rather than just being taller.  Probably won't notice a lot of height difference.
i find the rear of my zuk is saggin a bit, and with weight in it rubs like crazy, and gv coil cant be too expencive at the reck yard
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #16 on: July 29, 2012, 09:51:24 AM »
GV or XL7 coils would probably do you well.  More capacity for those trips and definitely sit higher than your saggy stockers.
Offline bush buster
  • 263
« Reply #17 on: July 30, 2012, 06:12:30 AM »
I never compared with a gv coil but the xl7 coils I put in my vitara add about 1/2" to 1" of lift and perform much better off road and loaded down.  And yes they ride rougher.
Offline diftoyota
  • 253
« Reply #18 on: July 30, 2012, 08:18:38 PM »
i dont care for how ruff they are, just want to get rid of my tire rub wen loaded, two in the truck it does fine, but with two other guys in the back and a case of beer it makes the rear tire rub like crazy.
