2nd battery/cb location
  • 19 Replies
  • 4106 Views
Offline fordy1
  • 101
  • I Love zooks
    • Outdoor Auto
Re: 2nd battery/cb location
« Reply #15 on: September 29, 2006, 05:23:44 AM »
fitting the base was easy, the remote face was not to bad
i drilled a small hole in the top right hand side of the space so that when the unit is removed you will not see the hole and only big enouph for plug to go through.
note: the gap behined the pocket is only 8 mm
once fitted i used double side tape to stick face in spot to keep the clean look...
and hand unit just fits when door is closed.
I supply GV Snorkels at outdoorauto.com.au
« Reply #16 on: December 21, 2006, 09:16:23 AM »
Had a friend that installed one in has GV '00  under the raido.
Geogre
Glad to see you "had" a friend.  ::)
What am I now, chopped liver?
Offline ZR2
  • 103
  • Powered by SUZUKI
    • See the best sidekick/tracker/vitara website!!!
« Reply #17 on: December 21, 2006, 03:11:50 PM »
see my cb location:
Offline DNZ
    • Alter Terra
« Reply #18 on: December 26, 2006, 10:52:20 PM »
Some more photos:
Offline ZR2
  • 103
  • Powered by SUZUKI
« Reply #19 on: December 27, 2006, 09:24:17 PM »
and see my fire Extinguishes location!! :
