235-75-15's-will they rub at all
  • 7 Replies
  • 3846 Views
Offline ZR2Trackerjoe01
  • 40
  • 02 Tracker ZR2,
« on: August 17, 2012, 05:30:14 PM »
My rims are off of an old ford truck, i read that they should fit but was wondering if the tires would rub anywhere. Its a stock ZR2 tracker.
02 ZR-2, Jeffs Kit, Doestch shocks, Warm Premiums.
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: 235-75-15's-will they rub at all
« Reply #1 on: August 18, 2012, 06:33:07 PM »
235s will rub on the inner FRAME during tight turns, even with a 2 inch lift.
Stock Tracker rim back spacing is around 4.25 inches.  Stock ZR2 rims are 6" wide.
So if the old Ford rims you are using are different than above (back spacing or width) you will probably experience more tire rub.  If they are 8" wide rims you may even get some rubbing on the top of the rear fender during compression.  On top of this is the plastic fender cladding on the ZR2 model Trackers which reduces the wheel well openings slightly.
235s fit on the stock Tracker rims just fine.
« Last Edit: August 23, 2012, 06:02:36 PM by nprecon »
Offline diftoyota
  • 253
« Reply #2 on: August 21, 2012, 11:03:25 AM »
mine fitted 235/75/15 with my 2" lift with no issue, got two other guys in town with stock trackers with those tire size and no issue either, depends if your coil springs have weeken or not.
« Reply #3 on: August 21, 2012, 01:35:55 PM »
My 235 75 15's rub at full turns. That's with a 2" spacer lift.
2001 4 door Tracker. 2.5 V6 4x4
235/75/15 Firestone Destination A/T's
Jeff's 2" spacer lift
Offline nprecon
  • 2318
  • 52
« Reply #4 on: August 21, 2012, 07:56:05 PM »
I've had a 2" lift on two of my 2nd Gen Trackers, running stock size rims (15X5.5) with 235/75/15 tires and had rub on the inside frame at full lock with all of them including:  Mchelin LTXs, Courser AT2s, BFG A/T KOs and the Courser C/ts I currently run.  The BFGs were probably the heaviest rub because of their side lugs.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #5 on: August 23, 2012, 11:29:20 AM »
Yep, they rub on the FRAME.  I've got the Tracker with BFG's that nprecon speaks of and the only rub I have with 235/75R15's are when the back of the tire that goes inward during a hard turn makes contact with the frame.  95% of the time I have no issues and it only does it when I'm turning hard like in a parking lot or directly next to where I'm trying to turn into.
No damage to the tires and just a "shiny" spot on the frame where the rub is.
Offline nprecon
  • 2318
  • 52
« Reply #6 on: August 23, 2012, 06:02:07 PM »
Yeah!  frame... not fender.  Thanks AJM!
Offline diftoyota
  • 253
« Reply #7 on: August 24, 2012, 09:57:30 AM »
ive checked with my buddys and they all got aftermarket rims, so the offset might be different
