i got a 2002 suzuki vitara with the 2L motor and 5spd trans. i did change my oil pan a few months ago. i bought the pan at the chevy dealer as i could not find any aftermarket and suzuki dealer is 3h drive away from me.
dealer told me it was easier to remove the diff and rack and pinion to get to it. but i find it alot harder to do this way. if id do it again id pull the motor out instead
the rack and pinion and diff has to come out, and wille removing the diff means some of the passenger side wheel parts got to come off to get the cv shaft out. and wen you are ready to remove the oil pan, it wont just slide out, you will need to shuve your hand in it to remove the oil pick up tube so the oil pan can come out, now this is the part i hated, there is no gasket for these, its made to put in silicone. now imaginge trying to put a oil pan pickup tube wen the silicone is aplied, its not an easy task. it is possible to do it, i did it myself, but i find it just a pain to do it this way.anyhow i find it will be way quicker removing the engine as there is less part to remove so less time removing stuff.
