Front diff/hub swap q's...
  • 33 Replies
  • 6175 Views
Offline CG98x
  • 38
Re: Front diff/hub swap q's...
« Reply #30 on: December 02, 2008, 06:20:08 PM »
Sidekick sport axle seems to works fine. It is the same length as the vitara axle and it has the slightly longer stub needed for the sidekick diff. I am up and runnin again with 5.13s and four wheel drive that should always works when I tell it to.
1999 Vitara 2.0l 5 Speed. 2 inch body and 2 inch suspension lift. 215/85/16 Capital AT's. Custom bumpers and a few other things 5.13's and no air diff.
Offline olija
  • 770
    • Check out my cardomain
« Reply #31 on: December 02, 2008, 08:19:43 PM »
CG98x, you're talking about the pass side CV assembly, right? If so, that is good news. That shouldn't be impossible to order from the local parts store.
Offline CG98x
  • 38
« Reply #32 on: December 02, 2008, 08:38:52 PM »
Yes thats what I'm referring to. I ran it pretty hard tonight to test it and didn't have any problems.
Offline donc
« Reply #33 on: March 24, 2011, 05:15:17 PM »
Is there anyone in Central Or southeast kentucky that can do this job for me?
