00 Tracker 4WD light not working, 4WD IS working
  • 1793 Views
« on: September 24, 2012, 11:06:01 PM »
New member, just picked up a 00 Tracker 2liter auto. The 4WD light isn't working,  I swapped the bulb with known good ones and even probed the cluster harness and have no power to the 4WD light.
I can hear the pump kick on when 4H is engaged and I have axle bind up when making tight turns in 4L. What would the next step be to test the circuit?
Offline talonxracer
  • 1284
Re: 00 Tracker 4WD light not working, 4WD IS working
« Reply #1 on: September 25, 2012, 06:41:24 AM »
The switch on the transfercase is probably faulty
  • 4314
  • 167
« Reply #2 on: September 25, 2012, 07:26:27 AM »
Actually - no - if the switch on the transfer case were faulty, the 4WD controller would never engage the pneumatic freewheel mechanism in the front axle - he's hearing the pump come on, so that switch has to be working.
HondaDNA - I just replied to your thread over at the Suzuki forums in some detail - what color wire to measure, what voltage to look for and so on - you should find what you need over there.
« Reply #3 on: September 25, 2012, 10:02:05 AM »
Thanks fordem, I'll hop over there and check it out.
Offline JayInBarrie
  • 107
« Reply #4 on: September 25, 2012, 04:20:42 PM »
Funny, I just bought a '99 1.6L today.
The 4wd was working, as the turned up gravel indicated, but the old owner had never seen a 4wd light come on.
When I got home I checked and there was a plug by the pump unpluged, plugged her in and "tada" the 4wd light came on. Maybe for the psi sensor to trip the 4wd light. ;D
99 2dr Tracker, 33" tires stuffed in, home made roof rack.
  • 4314
  • 167
« Reply #5 on: September 26, 2012, 10:20:53 AM »
There's only one electrical connector there - it has three wires, black, ground; red, +12V power to the pump and pink, feedback from the pressure switch to the 4WD controller.
Very simplified, here's the sequence of events - the 4WD switch on the transfer case tells the 4WD controller when 4WD has been selected, and the controller applies power to the pump and monitors the feedback signal - if it sees the signal go high, it turns the 4WD light on, if it does not go high after 10 seconds, the controller shuts the pump off as a protective measure. Assuming that everything is functional, the pressure from the pump engages a freewheel clutch transmissitng drive from the ring & pinion to the differential.
When you shift back to 2WD, the controller shuts the pump off & opens a "dump valve" releasing the air and disengaging the freewheel mechanism
