I'm stuck here. What's next?
I have removed the C-clip from the picture below. Does the next gear piece thats splined onto the shaft need to get pulled?
In the picture below I've removed the C-clip above the plastic gear and the c-clip below.
Whats next to completely gut it?
I'm building a toyota to tracker doubler. This is the first case like this I've worked on. A lot different than the 205.
Also, what is the proper procedure for removing the drift pins? The easy out mechanical extractor method used in the heavy truck manual didn't work at all on this...
Thanks.
