Another turbocharging/megasquirt thread!
  • 116 Replies
  • 40487 Views
0 Members and 13 Guests are viewing this topic.
Re: Another turbocharging/megasquirt thread!
« Reply #45 on: January 20, 2005, 07:51:28 AM »
I was doing research on how I could
convert a PC into an EFI system, the
MegaSquirt saved me from taking my
PC on the road   ;D
GTG guys
Lunch is over  1-1/2 hrs  ;)
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #46 on: January 20, 2005, 07:54:11 AM »
the
PC on the road   ;D
No it didn't!  You still drag your laptop all over the place!!!
8)
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline explosivo
  • 3157
« Reply #47 on: January 20, 2005, 10:35:36 AM »
Nah you gotta build a fuel rail and weld or tap bungs into the intake for the new injectors. It seams intimidating but now that I have seen wilds I don't think it would be that bad.
would you all be interseted in some parts precut for the header? Like the header plate or the collector plate. I think Wild and I can spend an afternoon and make some. I don't wanna make headers cause at this point every rig is different and that is something you gotta design but we can cut the plates for ya. I think that is where alot of the time is eaten up.
Thanks
Wayne
I'd definately be interested in the header flange, as I have no way to make those with any precision. Let us know some prices!
omghi2.us[/url]
Offline 1bigtracker
  • 3409
« Reply #48 on: January 20, 2005, 10:46:15 AM »
Thanks
Wayne
i've been waiting to hear that for a long time.  what will they be cut with and how thick will they be?
stu
« Last Edit: January 20, 2005, 10:46:54 AM by 1bigtracker »
Offline zukizzy
  • 123
  • Give it a bump, see what happens!
« Reply #49 on: January 20, 2005, 10:47:15 AM »
I'll talk to Darrin it is his design so he will have to set the price.
Thanks
Wayne
Clearly a road
Offline zukizzy
  • 123
« Reply #50 on: January 20, 2005, 10:50:11 AM »
stu
If it is just a couple a plasma cutter then a cleanup with a die grinder. if it is a bunch then we will see about lazer or a CC flame cutter.
1/2" steel bar stock
Thanks
Wayne
Clearly a road
Offline CrazyCooter
  • 20
« Reply #51 on: January 20, 2005, 12:57:46 PM »
« Last Edit: January 20, 2005, 12:58:29 PM by CrazyCooter »
« Reply #52 on: January 20, 2005, 01:17:12 PM »
8)
Well ya, but I was thinking about a desktop
PC system   ::)
« Reply #53 on: January 20, 2005, 01:21:52 PM »
Sweeeeeet, Bro Thanks!!!
;D
Did you just tap the intake or weld bungs in?
I welded them in, but I think I would use
threaded bungs on the next 8V manifold
I build.
Offline HUMZUKI
  • 117
  • Fool!
« Reply #54 on: January 21, 2005, 08:51:23 AM »
Are these the injectors your talking about. I don't see how they would use the same ones on N/A and turbo/supercharged fords.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33553&item=7949305029&rd=1
« Reply #55 on: January 21, 2005, 12:32:43 PM »
I don't think that I would trust that guy,
I know the Turbo 2.3 uses 35 PPH and the
N/A  uses 25 PPH, the others are probably
similar, somewhere between 22 and 25 PPH
I have an extensive list I could post, but
it's mostly for looking up sizes and the size
of injectors for pulling from vehicles
Offline 90Stomper
  • 427
« Reply #56 on: January 22, 2005, 12:47:32 PM »
hi all, havnt been around for a while, honey do list ya know... ;D
this subject is WAY beyond me, and after going to every link i am pretty impressed with you all that are biting this off.  i do however have a few VERY simple questions after reading all this.... if you dont mind simple.
Is there a way to move or remove my tbi to increase air flow (1990 8v)?
i have seen 'squirel cage' electric add on blowers that go on the air intake, they worth a crap?
and lastly, will the MS or MSII do anything on my stock setup?
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
« Reply #57 on: January 23, 2005, 11:19:55 PM »
Taking some measurements off the stock TBI I would guess that the restriction would be around the injector  and the throttle butterfly. You fit a different injector somewhere else bock off the holes and then bore out the base of the throttle body and fit a new larger butterfly. Then add a MS to get the fuelling right . Its a large amount of work and probably wouldn't give much of a gain, if any.
Offline explosivo
  • 3157
« Reply #58 on: January 23, 2005, 11:50:58 PM »
Now what about doing that with forced induction? Or the TB work and then porking and polishing the head/intake with a turbo?
omghi2.us[/url]
« Reply #59 on: January 24, 2005, 02:14:35 AM »
I was toying with the idea of twin TBIs,
mostly to get enough fuel, as I needed
a little over twice the fuel a stock TBI can
deliver, this was before I found MegaSquirt,
I would have done it if I could reliably weld
aluminum, but the cooling system runs thru
the intake manifold, and that seemed like
such a pain to work with and route to the
radiator
