What year xl7 front housing in a kick
  • 1714 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« on: December 16, 2005, 03:09:22 PM »
I want to do the heavy duty build up but I'm not shure what year the housing comes in. I know I need a 99 g/v 5speed 3rd. I will be using the tt front locker/carrier.
   Kevin
Offline the_maplebar
  • 466
Re: What year xl7 front housing in a kick
« Reply #1 on: December 16, 2005, 06:18:41 PM »
I knew I had seen the answer somewhere.  Here you go.
The earlier XL.7's with automatics still had aluminum housings with a steel 3rd member, with the manuals having steel housing and 3rd member. The housing and third members were upgraded to steel in 2003 for both tranny combos
If you're unsure of the metal, try to stick a magnet on it.
Good Luck, Eric
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: December 17, 2005, 10:55:15 AM »
there is an article on the conversion here at ZukiWorld.  It describes which year to look for.
If you can't find it, go to Ack's FAQ (use the link in my signature) and do a forum search for XL7 for a link to the article.
Ack
« Reply #3 on: December 17, 2005, 12:52:23 PM »
The XL7 has a different third member mount, a GV one would be an easier fit as it is a straight swap. The steel casings were fitted to the V6s.
« Last Edit: December 19, 2005, 03:42:39 AM by Zukipilot »
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #5 on: December 19, 2005, 09:14:00 AM »
They don't say which year on the Xl7 housing I know I need a 99g/v 5spd 3rd member. I just don't know on the housing. Zig I am going with Hutch's set up and the new tt locker.
    Thanks
     Kevin
Online ebewley
  • 6544
  • 64
« Reply #6 on: December 19, 2005, 09:26:13 AM »
    Thanks
     Kevin
There is a GSP part number "somewhere" here on the forum.  ;)  If you're going to get a used one take a magnet along with you that will make it easy to tell. Here's what I believe to be true... The first two model years had both aluminum and steel. The autos were aluminum and the manuals were steel. In 2003 all front housing were steel. You are talking of the center section housing and not the 3rd member housing, right?
XL.7 3rd member housing:
http://www.zukiworld.com/forum/index.php?topic=4408.0
Good Luck, Eric
« Last Edit: December 19, 2005, 09:28:35 AM by ebewley »
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #7 on: December 19, 2005, 09:48:25 AM »
Yes the housing not the 3rd member. Thanks Eric I would have asked jason but he is over seas.
      Kevin
