Project kimera Buildup
  • 24 Replies
  • 3641 Views
Offline rockrat
  • 196
  • Got Ringr
Re: Project kimera Buildup
« Reply #15 on: December 19, 2005, 12:02:09 PM »
Is it possible to get a weight idea to the tubing added? Or a final weight at completion? To compare to a Sami, stock and mod'd (the normal way LOL)....
Our normal full cage is about 125#'s.. The exo tubing total is just over a full interior cage. So I would guess 180#'s But we have removed that much weight in original equipement.. We are going to weight it before we deliver it to get an actual right now its all guess work
Offline rockrat
  • 196
  • Got Ringr
« Reply #16 on: December 19, 2005, 10:20:49 PM »
Work on the door latch not finished yet,, and Bob got some tube in on the rear..
Offline 89kick
  • 27
  • I LOVE MY LIL ZUK
« Reply #17 on: December 21, 2005, 12:43:37 PM »
i can't wait to see the end result this thing is gonna be mean.
*89 kick, witha  6" calmini super articualtion combo lift.  New interior 100% 1/8inch neoprene seats that 100% waterproof.  33x12.50 Wild Country EXTs on 15x10 slotted mag alumminum wheels.  Comp level Stereo system. and the Stock 1.6-8valve for now.
Offline rockrat
  • 196
  • Got Ringr
« Reply #18 on: December 21, 2005, 01:25:41 PM »
Other then turning some caps in the lathe for a few tubes we are done with the tube work bending and fitting. I should be able to finish tig welding everthing up tonight..
« Reply #19 on: December 21, 2005, 01:45:12 PM »
I was wondering that too, I guess 180lbs isn't too bad. Also it does looks fantastic and thats some real quality looking work. 8 months is pretty good, those door latches must have taken a good few hours to fab.
Offline rockrat
  • 196
  • Got Ringr
« Reply #20 on: December 21, 2005, 08:10:55 PM »
We recieved the rig the middle of last January.. After we finished the show truck we started working on this mid April.. not a bad time line so far.. There has been alot of just looking, measuring and designing that took place to gain as much real world driveability into an unbuilt rig.. The owner wants to do quite a few thing's with it.. It wont be the best at all but should perform well in applications.. time will tell.
As for the latch mech, couple hours after i new how I wanted them to work. I needed to be able to reproduce these in a fasion to make the doors affordable and at the same time fit every rig..
Offline rockrat
  • 196
  • Got Ringr
« Reply #21 on: December 22, 2005, 11:01:48 PM »
Ok latches are done on and adjusted, tube doors are capped..
What you see is the housing I made to fit our latch.. has some adjustability in and out. Up and down is done by the hinge.
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #22 on: December 23, 2005, 08:37:59 PM »
This photo looks like a sweet start on a Zuk look alike tube chassis. I would have had a hard time not linkin it and throwing some axles under it.
Mike
Offline rockrat
  • 196
  • Got Ringr
« Reply #23 on: December 24, 2005, 07:18:06 AM »
Mike
Ya I know, I have the entire cage design in Bend tech so I will be able to make another.. I have definetly thought about making a mid engine crawler with this as the chassis...
Offline rockrat
  • 196
  • Got Ringr
« Reply #24 on: December 24, 2005, 09:52:00 AM »
Between yesturday and today so far...
All tube work finished, and is being double checked, Front light panel which is polished stainless has been blued with a torch and repositioned in the grill. Front of bumper was reworked to get rid of the giant Reciever Dick look.. It is still usable by way of bottom access. driving light tab is now welded into the grill. And I am finishing up the spinner for the spare tire carrier..
rear of bed rails plugged and tig'd
reworked bumper center
showing off tig welds LOL
new fuel pump, Walboro 255 lph with earl's pre filter and new -6 fittings
Better shot of the fuel lines and billet holders..
Starting the spinner for tire carrier
