Orange rig is getting a makover!
  • 233 Replies
  • 39932 Views
Offline kozaz
  • 168
Re: Orange rig is getting a makover!
« Reply #105 on: February 17, 2006, 07:14:26 PM »
Mike,
Don't know if this would help...Older corvettes have IRS with a center section that has no tubes...U-joints go on a flange with 4 bolts...That would kick |removethispart|@$$ in the front and rear..You could mount in the center of the front.The drive shaft would be sidways,but the housing woundn't move..All kinds of things could be done around those center sections...Let me know if you would like some pics..I got a 78 corvette,It has all kinds of mounting holes,Camber bars,leaf springs etc. all bolt to the center..would be a good center...
Later Tom K.
I actually have a center mount front diff already. That is a good Idea though. I will definately keep that in mind for a build in the future. Thanks. Do you or anybody else know what rearend they used? Is it a dana 44 center?
Mike
1984-87 Corvette rear ends have parking brakes inside of the rotor, quite similar to 65-82 Corvettes. This allows you to use a minimum of 15" aluminum (not 15" steel) wheels.
1988-96 Corvette rear ends have parking brakes built into the calipers. This allows you to use a minimum of 16" aluminum (not 16" steel) wheels.
Both generations came in either a Dana 36 or Dana 44.
1984-96 Automatic transmission Corvettes have Dana 36 rear ends. Factory G.M. gear ratios range from 2:79 to 3:07.
1984-96 Manual transmission Corvettes had Dana 44's. Factory G.M. gear ratios range from 2:79 to 3:43. These are harder to find, and more ring and pinion ratios are available aftermarket.
The above info came from http://www.progressiveautomotive.com/sweetrearaxle.htm
And the following came from Randy's Ring and Pinion:
only Dana 36 Ring and pinions:
YG D36-259 D36 ICA 2.59 R&P ONLY Dana D36 2.59
YG D36-308 D36 ICA 3.07 R&P ONLY Dana D36 3.07
Deepest ring and pinions gearing for regualar cut Dana 44 gears (I think these would work):
YG D44-513 D44 5.13 R&P Dana D44 5.13
YG D44-538 D44 5.38 R&P Dana D44 5.38
YG D44-589 D44 5.89 R&P Dana D44 5.89
Deepest Reverse cut Dana 44 gearing:
YG D44R-488R D44 4.88 REV R&P Dana D44 4.88
YG D44R-513R D44 5.13 REV R&P Dana D44 5.13
YG D44R-538R D44 5.38 REV R&P Dana D44 5.38
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #106 on: February 17, 2006, 11:06:03 PM »
progress may be a little slow but should be worth it.   ;D ..( inside info. )     stan
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #107 on: February 17, 2006, 11:09:55 PM »
Hey quiet you! Arent you supposed to be in bed? ::)
 ;DMike
Offline 37kicker
  • 319
« Reply #108 on: February 18, 2006, 10:23:04 PM »
I  DON'T   SLEEP !
Offline track_this
  • 332
« Reply #109 on: February 22, 2006, 02:36:26 AM »
do you have any pics of it ???
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #110 on: February 24, 2006, 12:34:58 AM »
I do but they wont be released cause there will be a Zukiworld write up on it.
Mike
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #111 on: February 24, 2006, 12:50:37 AM »
Sorry. tried to post something but Zukiworld is comming up with an error.
Mike
« Last Edit: February 24, 2006, 01:00:19 AM by Mikerpm4x4 »
Offline 37kicker
  • 319
« Reply #112 on: February 25, 2006, 07:32:02 PM »
AH, AH, i can't do it mike will   KILL   me.  :-X  stan
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #113 on: February 25, 2006, 08:09:12 PM »
Still wont work :'(
« Reply #114 on: February 27, 2006, 04:37:06 AM »
The error is still coming up, I sent the great Zukiworld Guru a PM telling him about the error. We will let you know when it is fixed  ;)
  • 6558
  • 64
« Reply #115 on: February 28, 2006, 01:36:26 PM »
Yeah, yeah, yeah... Yuk it up fuzzball...   :)
« Reply #116 on: March 01, 2006, 04:19:41 AM »
Finally the first SPY cam photo of the Orange Rig and it's make over  :o
OK , it's only a part off of it. BUT:
If you are the first Zukiworld member to properly identify this part, wewill send you a free Zukiworld decal  8) So let's see who knows their stuff.
« Reply #117 on: March 01, 2006, 04:24:59 AM »
NO STAN AND MIKE, you can not win  ::)
Offline bbagwell
  • 278
« Reply #118 on: March 01, 2006, 04:57:57 AM »
Lower control arm?
2002 Suzuki Grand Vitara
1983 Toyota PU
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #119 on: March 01, 2006, 06:22:43 AM »
Steel  ;D
How about an upper control arm?
« Last Edit: March 01, 2006, 06:26:46 AM by Uncivilized »
