Rear light wiring - Brake/Turn Signal - Samurai
  • 8885 Views
Offline ShawnQ
  • 64
  • Cruising the Beaches of South Texas!
    • Lone Star Sharkers
« on: December 06, 2005, 02:44:44 PM »
Before I build a bumper next week for the back end of my Samurai, I want to make sure I've got enough lights to take care of everything I need.
While looking at the factory wiring, I came up with the following:
Reverse Light : Red Power / Black Ground
Running/Brake Light: Red Power / Black Ground / Green & Yellow for BRAKE LIGHT
Turn Signal: Green & White / Black Ground
My question is this: I want to have only two lights on each side of my bumper, a red and a white.
I want the white to be JUST a reverse light. No problems with this one.
I want the red to act as a running light, brake light, AND blinker.
How can I do this?
If I run the Green & White (blink) and the Green & Yellow (Brake) together, the blinker will work, but ONLY if I am not using my brakes.
Is there a simple way around this without buying a different light? My current light has a 3 wire plug, which wont allow a blinker and a brake unless they are combined.
I'm thinking that I could modify the light by adding another bulb/socket. Any easier ways I am over looking?
Thanks
Shawn
« Last Edit: December 06, 2005, 02:48:59 PM by ShawnQ »
'88 Samurai - SPOA Lift, Stock 1.3L, 235/75-R15's
'04 Dodge Ram 2500 Cummins - 4wd, 2" leveling kit, Off Road Package
Offline Ian
  • 50
    • Island Rock Crawlers
Re: Rear light wiring - Brake/Turn Signal - Samurai
« Reply #1 on: December 08, 2005, 10:32:37 AM »
You need to purchase a trailer wiring converter.  It is put into your harness and converts the wiring to work with single trailer lights that share brake/running lights/turn signal.  Should only be a few bucks and available at any auto parts place.
Offline jbzukin
« Reply #2 on: December 08, 2005, 12:22:18 PM »
I tried this on my truck and it didn't work. it seems that it could not process the hazzard flashers, they would not blink. this was a kit from a trailer shop so I don't know if they are all like that.       ??? I ended up getting two small yellow lights that are for turn signals only. the stop and brake are no problem though.
Offline suzuki1750
« Reply #3 on: December 09, 2005, 07:34:14 PM »
I converted mine years ago with just four relays. It worked perfect, until i dunked them under water..
Here is a wiring diagram
http://community.webshots.com/photo/197934187/520214090zZqcEx
« Last Edit: December 09, 2005, 08:57:48 PM by suzuki1750 »
Steve Schilling
Barnhart, Mo.
90 Samurai
http://community.webshots.com/user/suzuki1750
suzuki1750|removethispart|@cs.com
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #4 on: December 09, 2005, 07:59:49 PM »
Yep.  What Ian sez.
I installed a trailer converter that worked with my three-wire (plus ground) trailer.  Walmart fer sure, but if you have bad feelings about them almost any autro parts store should have a universal kit.  Connect it up and drive your tail/turn/brake lights on the bumper from it.
Ack
