locker
  • 1403 Views
Offline SidekickMN
  • 58
  • Waiting on  Money  for  Body Lift
locker
« on: November 30, 2005, 07:36:18 PM »
When i order the rear locker do i want to order it with the coupling or not.  Thanks
1994 Sidekick, hard top, soft top, custom bikini top
30x9.5x15 mud tires
RRO 2.5"
Herculiner interior
Re: locker
« Reply #1 on: November 30, 2005, 09:18:42 PM »
With out(you want the cheaper one.)they work better.
Offline MIDZUKI
  • 17
  • "if it breaks, just put some more weld on it"
Re: locker
« Reply #2 on: December 15, 2005, 12:07:12 PM »
what do the side couplers do? why dont you want them?
87 zuk, locked, geared, mightykong, 33's
Offline mbmarkyb
  • 461
    • UK Vitara
Re: locker
« Reply #3 on: December 15, 2005, 01:11:31 PM »
across the pond we call them side gears ,the mesh with the sun & planet gears and when you take them out to fit the lockrite pieces you see you side gears /cuplins are all good.
I doubt yours have worn unless its done 200k on th eclock
I expect rocky road will say the same "with out
Markyb (UK)
UK Vitara JLX SE
Re: locker
« Reply #4 on: December 16, 2005, 09:23:52 PM »
if you bend your axel housing the side couplers that come with the lockers are a finer tooth count(smaller teeth)and will not engage, the stock side gears will engage unless you bend things up so bad that you could see it.
