Sagging Driver door, any tips on a fix?
  • 1800 Views
Offline Festiva
  • 92
« on: November 30, 2005, 08:02:12 AM »
Hi there fellas, my drivers door is starting to sag Bad!, is this a common problem on a tracker/sidekick? looks like either the pin might be worn but almost looks like the metal behind the hinge is rusty!,...
Anyone ever have this problem and happen to have any fix tips?
 Thanks!
    Jason
Offline Cwkick
  • 888
Re: Sagging Driver door, any tips on a fix?
« Reply #1 on: November 30, 2005, 08:07:56 AM »
It is a common problem.  I had to have a top hinge rewelded once.   :-[
Cwkick
« Reply #2 on: November 30, 2005, 08:11:14 AM »
My top hinge was pulling off the body,
but that's after the door about got pulled
off backwards, I knocked the hinge mount
spot in some and welded the hinge back on
Offline CBTracker
  • 140
  • OH, you think I can't make it through?
« Reply #3 on: December 05, 2005, 10:20:48 AM »
On my tracker I just picked up some door pins from a local parts place and drilled out the old ones, put collars in and popped the new pins in, works great, also some washers btween the hinge and truck/or door work good on other cars, not too sure about the sammie though
96 Tracker 2dr on 215s, 2inch suslift soft top, GPS Nav, Light bar.
89 Tracker 2dr hardtop, 235s 1inchsus custom body work, push button starter
« Reply #4 on: December 05, 2005, 02:35:27 PM »
The sammies are easy, you just loosen the four bolts and move the door where ya want it and tighten them back up. I found an easy way to loosen them too.  ;D with out messing them up.
Offline Blasted
  • 63
  • Yea.. its a Kick.. Keep dreamin.
« Reply #5 on: December 05, 2005, 08:55:34 PM »
I paid a local body shop to replace mine.. Cut the old soft metal out behind the hinge points and replaced it with thicker guage steel.  Cost me 200 but came with a lifetime warranty. Its a totaly common problem. The dude at the body shop said mine was at least the 12th or so hes worked on.
93 Sidekick 2Dr.  2"body lift.  30" Tires. 1.5" Coil spacers. 4 door coils. 2"strut spacers. K&N Factory replacement filter. 2.25" Cat back, with glass pack.  Custom ground High torque Cam shaft. And CB for talkin trash.
Offline SunrunnerGT
  • 163
  • 1994 Pontiac Sunrunner GT and 1996 X90
    • Aaron's Suzuki
« Reply #6 on: December 09, 2005, 01:52:07 PM »
i just had mine replaced with new ones. The weird thing is, that the top hinge was more money than the bottom one!? And they look the same gezzz ::)  The one was $45 and the other was $58. Oh and when i asked whats the diff no one could give me an answer ::)
Sunrunner GT, Gold Trim Level
