If I remember right, there is a small access panel on the passenger side of the throttle body. It is held on with 3 screws.
Remove the cover.
Put a small piece of tight fitting hose on the nipple, with the other end plugged, with a screw or bolt.
Reinstall the cover.
What is happening is there is a vacuum leak. That is allowing it to suck air. The piece of hose you are using, is making a tight seal. Your high idle choke setting will not work now. It will take a little longer for your engine to warm up.
Maybe someone will provide you with the link, but this is about the best I remember.
