Clutch problems?
  • 1444 Views
Offline prairie_dog
  • 234
  • 85/413 tin top
Clutch problems?
« on: November 16, 2005, 04:49:11 PM »
 With the 1.6 swap I did a new clutch, throw out bearing, pilot bearing and re-surfaced the fly wheel.
 Made it to work today and had no clutch when I got to my parking spot? I made it home with no clutch, if I push the pedal you can hear the rpm's go up like it's working but you can't put it in gear? ( the cable isn't broken and I tried adjusting it in the parking lot but didn't help)
 What else is there to go wrong, that you can't engage or dis-engage the clutch?
IF YOU CAN'T FIND'EM        GRIND'EM  :( :( :( :(
 Steve :)
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: Clutch problems?
« Reply #1 on: November 16, 2005, 09:55:54 PM »
did you make sure the shift fork was sitting on the throw out bearing the right way - sometimes they can not sit right and wont release the clutch 100%
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline maybe2fast
« Reply #2 on: March 14, 2006, 10:34:12 AM »
I am having a similar problem. was going down the express way pushed the cluch in pedal felt weird and the clutch wasn't disengadging.
Offline ROSS
  • 1412
« Reply #3 on: March 14, 2006, 05:59:42 PM »
have someone push the clutch while you look underneath to check the cable. had one start to fray inside made the pedal feel funny.
        Ross
