I finally got a day off work todayÂÂ
Thought I'd make a start on swapping the LWB brakes onto my Vit.
Pic showing how much thicker ventilated disc is. I contemplated spending some time cleaning up the disc but then decided against it as it will only go rusy again first time it rains:
This was a surprise, the top disc is the original 8V SWB with Lucas/Girling caliper, the lower is the LWB disc, notice that the SWB disc has a much greater swept area. The other side of the LWb disc was similar to the SWB, both discs were the same
Ventilated disc in place. I had to spend some time cleaning up the rear mating face with a wire brush to get the disc to sit square. When I first checked the runout I thought it was warped! The disc shield/guard rubbed a little as Wild said it would. I considered modifying it but I have had problems with trapped stones (what a noise!) in the past so I just cut it off.
LWB piston next to SWB caliper, not easy to see the difference like this
Vernier calipers show a difference of around 4mm, LWB is 53.5mm against 48.1mm for the SWB.
