LHS driveshaft on the RHS
  • 45 Replies
  • 10916 Views
Offline cj
  • 1276
  • I drive a really big ATV
Re: LHS driveshaft on the RHS
« Reply #45 on: December 27, 2009, 03:25:52 PM »
Just thought I'd let you know that this is still working fine. It is currently in my 2.0 swb which has the same chassis setup as the Sport. Apart from needing to mod the diff drop brackets due to the different chassis width, I also needed to make up a spacer (the flanges cut off the LHS inner axle shafts work for this) to use with a standard 1.6 LHS CV/axle for use on the RHS as the diff is positioned slightly differently in the Sport chassis and you can't use the Sport LHS CV/axle due to its longer length.
