towing on mudders
  • 16 Replies
  • 3311 Views
Offline Chief
  • 678
  • Whaddya lookin at??
Re: towing on mudders
« Reply #15 on: March 19, 2005, 08:24:41 AM »
If you rent a dolly, be sure to take out the rear shaft for any trip over 50 miles. .
Good point! forgot to state that. Yes, I a;lwats take mine out.
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #16 on: March 20, 2005, 02:03:00 AM »
actuallly when flat towing u put the t-case in nuetral and the tranny goes in second to keep the out put bearing form spinng on the tranny because it want get oil and will burn up. i recomend if u flat tow to disconect ur drive line if u r going more than 100 mile. it only takes a few minutes and then there is nothing to worry about. plus u can forget all what in nuetral and what gear. by the way it does not matter what gear u put it in i actually us 4th incase the t-case happens to lock/slides into gear the rear tires don't lock up and the sami goes all over the road possibley causing a collision.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
