JB Weld to correct the damaged keyway and some Loc-tite 609 on the crank shaft to Lower timing pully mating surface.ÂÂ
Loc–Tite # 609, Cylindrical Type ( Green ) high viscosity / high temperature, and # 680, medium viscosity / high strength. This is used when you must fill and ‘ voids ‘ or wear on a shaft when mounting a gear or pulley. It is usually not necessary to use any heat on this type to make it release. Remember to clean the oil off the mating parts before using Loc–Tite. Acetone or plain alcohol usually works well.Looking into possibly drilling and taping the (Crank / pully) mating area opposite the keyway and adding a set screw to take some of the load from the key.
For now I'll probally just stick with the JB and Loc-tite. My machinist friend with the Kick on 36's just made this repair on his kick and said no need to add the Set screw.
I took 12 different pictures of the dammage these were the only two that turned out. The crank key way is egged out toward the mushroomed key.
