not quite waterproof
  • 16 Replies
  • 2984 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: September 18, 2005, 08:10:01 AM »
but getting there
Offline Dihnekis
  • 398
Re: not quite waterproof
« Reply #1 on: September 18, 2005, 08:22:54 AM »
Damn that thing is awesome, what all have you done to waterproof it besides the snorkel?
1988 Suzuki Samurai
Offline Memphis
  • 107
  • Need a Rig
« Reply #2 on: September 18, 2005, 08:37:04 AM »
hahaha that was great man!
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #3 on: September 18, 2005, 09:24:14 AM »
Hahaha, Would you even need a snorkel to go in water that deep?
Offline bandit86
  • 1641
  • elv8rguy
« Reply #4 on: September 18, 2005, 07:34:02 PM »
your stock  air intake is beside the headlights, I had water over the hood several times.  Basically, all I have is ignition protector on the wires, breathers relocated to the inside of cabin, all holes athat leak are plugged.  Trial and error though, still leaks from the dashboard somewhere
« Reply #5 on: September 18, 2005, 10:33:17 PM »
That's probably the fresh air intake
Leaking thru the vent system   ;)
« Reply #6 on: September 19, 2005, 03:30:45 AM »
That is sweet. Add a little wright to the back and fix that firewall leak and you can turn it into a boat  8) We want to see a paddle tire crossing when you get it water proofed  ;D
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #7 on: September 19, 2005, 07:58:50 PM »
My kick takes air in from behind the drivers side fender.  I'm thinking of making a snorkel.
Offline Dihnekis
  • 398
« Reply #8 on: September 19, 2005, 09:13:19 PM »
You need to rig up a propellor like that one samurai has.
1988 Suzuki Samurai
Offline andyt87
  • 146
  • I LPVE ZUKI WORLD!
« Reply #9 on: September 21, 2005, 02:57:56 AM »
the link didn't want to work for me... but im guessing you did something extreme!!!  ;D
With the doors as standad, does water come in through the seals???
1988 SJ 413
1986 SJ 410
1992 Samurai Sport
1989 Santana 410
Offline bandit86
  • 1641
  • elv8rguy
« Reply #10 on: September 21, 2005, 04:36:46 AM »
not too bad. if it gets worse, I'll put on a bead of urethane so the rubber will be more compressed
Offline echojeff
  • 414
  • Lo que sea
« Reply #11 on: September 21, 2005, 05:44:04 AM »
I sent this link to my cousin, here is what he said.  "He needs to put some big holes in the floor board so the water can get in and out easier.  That way  it might sink enough to get some traction."   ;D
LOL
Jeff
95 Kick 4dr JLX.
Offline CuriousKid
  • 31
  • I'm Just Curiously Inquiring...
« Reply #12 on: September 21, 2005, 11:14:42 AM »
Now that's just plain awesom!!!   ;D
Offline bandit86
  • 1641
  • elv8rguy
« Reply #13 on: September 21, 2005, 07:52:16 PM »
it has holes, called drain plugs.  care to guess what happens when the ecu gets wet?  Water stays out till further mods are done
Offline Mythose
  • 361
« Reply #14 on: September 22, 2005, 09:01:14 AM »
ok i have like 15 pop up blockers evedently
 and evedently i need itunes  ??? but I am sure it will be worth it.
