new Jimny
  • 21 Replies
  • 4510 Views
Offline bus_driver
  • 479
  • the voices tell me different things
Re: new Jimny
« Reply #15 on: March 19, 2005, 03:48:31 AM »
my dad was trying to import bikes (motor that is) from england and the only way we could bring them in was used so they would have to put something like 100kms on them and ship them as used. don't know if it is the same for vehicles....but I want one
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline takai
  • 907
Re: new Jimny
« Reply #16 on: March 23, 2005, 12:02:47 PM »
I heard a rumor that the Jimny's were carbed. If that is the case getting them stateside would be a monumental undertaking. They won't have an OBD II sensor port. No port, No import. Unless it has an OBD port to plug into and be tested you can't import a new vehicle. If it were 20 years old which would classify it as a classic then you could do it. I suppose if you could find someone overseas that could put EFI on it for you ($$$) then I think that getting one stateside is going to be pretty tough.
'Cause, I am to misbehave.
Offline Submercer
Re: new Jimny
« Reply #17 on: March 23, 2005, 12:54:59 PM »
The article in the New Zealand 4WD mag about it, titled "Full of Surprises" lists it as having "four valves per cylinder, variable valve timing, multi-point injection" doesn't look like a carb to me.
I'll be looking to get one of these once the price is right.  2003-04 models had pretty good specs and they're going for around $NZ13,000 (list $19000).  The new one has lower gear ratios but less ground clearance.
Steve.
'92 FI 1600 Softtop Sammy ARB front and rear.
'92 Escudo
97' 2.0l SWB Vitara
Re: new Jimny
« Reply #18 on: March 24, 2005, 04:23:38 AM »
UK models have always been MPI, my GFs is distributorless ignition too. The Jimny name has been in use in the Far East for many years though so maybe they were refering to an earlier model like the Samurai.
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: new Jimny
« Reply #19 on: March 24, 2005, 04:29:38 AM »
In those places the Samurai was named Jimny indeed  ;) I think that's what it is.
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline takai
  • 907
Re: new Jimny
« Reply #20 on: March 24, 2005, 01:16:15 PM »
Thanks for letting me know that. My mistake. :P Looks like my info was wrong. You learn something everyday.
Offline davekike
  • 10
  • o sami!
Re: new Jimny
« Reply #21 on: March 24, 2005, 02:58:32 PM »
New sami is looking good! :)
