Tires for stock kick
  • 1601 Views
Offline SNAFU
  • 40
« on: August 30, 2005, 07:30:59 PM »
Hello all, my first post here.  Awesome forum.  Luckily I was referred here by some nice people on the offroad.com zuke board.  I'm buying a 97 5 speed 2dr Tracker 4x4 with convertible hardtop.  Its going to be a daily driver but I also would like to do some light to moderate wheeling with it.  For now I don't want any lift other than what tires will provide.  I'm thinking hard about 235/75/15 BFG TAs.  I hear they are the biggest that will fit a stock truck.  I'm also considering 30.9s as I hear only mild hammering is needed.  Is this good information or am I off base?  Also, if I go with the 30.9s will the 16v engine be enough to pull hills on the highway in 5th?  If not will an intake/exhaust add enough power?  Any advice is appreciated.
Thanks!
« Last Edit: August 30, 2005, 07:43:43 PM by SNAFU »
Alan
When I grow up I want to be Stewie Griffin.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Tires for stock kick
« Reply #1 on: August 30, 2005, 07:37:56 PM »
In my experience, 215-75-15's on the stock silver steel wheels rubbed the frame when turning. I could have adjusted my steering stops to fix this, but I need all the turning radius I can get. That said, you might want to invest in a set of rims that sit out a little further from the frame with bigger tires. I would suggest 15x7" rims with around 3.75" of backspacing for either 235's or 30's. They'll clear better...
The 16 valve should have plenty of power to turn the bigger tires. I don't know for sure if you could pull hills in 5th still, though. Depends on the hill. LOL! And intake/exhaust upgrades certainly wont hurt at all.
« Last Edit: August 30, 2005, 07:40:49 PM by Digger »
« Reply #2 on: August 30, 2005, 09:15:58 PM »
I've been running 235/75s with 15x8 rims and 3 3/4 off-set
on my 97 Kick with no lift.
It rubs a little bit on the front bottom bumper at full turn but it trims up easily.
and a little in the rear when loaded down.
Heres my 95 2dr (way back when) with 225/75s on 15x7s (whatever stock offset for the wheels where then)
NO rub anywhere and looked alot better than stock.
I really liked this pic.
« Last Edit: August 30, 2005, 09:20:22 PM by HotRod »
« Reply #3 on: August 30, 2005, 10:08:25 PM »
I ran 235 tires for years on stock rims,
ya, they rub a bit, who cares, they look
great and the power is still good.
Offline SNAFU
  • 40
« Reply #4 on: August 31, 2005, 05:27:38 AM »
Thanks for the replies.  Looks like I'll go with 235s and if there is rubbing I'll deal with it.  :)
Alan
Offline Cwkick
  • 888
« Reply #5 on: August 31, 2005, 07:24:21 AM »
I have a 97 two door, five speed.  I needed a two inch lift to clear my 235 BFG's.  They still rub a little do to the wheel offset.
It drives much better with the bigger tires.  You won't be disappointed!
Cwkick
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #6 on: August 31, 2005, 10:41:30 AM »
Will you have the power to pull the hills in 5th gear?
Boy, is THAT a loaded question!
Let me tell you about MY expertise in this area.
Elevation above sea level MATTERS.
I live 9,000 feet above sea level (2,727 Meters, for you metric folks).
My STOCK 4-door with the 1.6L 16 Valve engine can't make it up to the Eisenhower tunnel on I-70 (elevation about 11,000 feet - 3,353 Meters) in 5th gear.  It's down to 4th or even 3rd on STOCK TIRES.
My 2-door 1.6L 16 Valve - the Gnewt - with 31 X 10.50's (soon to be 33's) even with the 5.83:1 Ring and Pinion gears, is DEFINITELY down to 3rd gear, and maybe even 2nd on a bad day.
Don't worry so much about climbing those hills.  You'll survive a downshift!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
