lock right diffs
  • 1891 Views
Offline madvitara
  • 45
  • Mud i love it
lock right diffs
« on: March 25, 2005, 06:32:28 AM »
Does anyone now if a samurai lock right diff will fit in a side kick housing?
Offline SuzukHunter
  • 70
  • CAN YOU SEE ME NOW??
Re: lock right diffs
« Reply #1 on: March 25, 2005, 10:12:38 AM »
should they are a little smaller.i know that a kick will fitin a sami hausing.
Offline coyhunter
  • 94 Tracker
« Reply #2 on: March 25, 2005, 11:46:29 AM »
Think so give hawk suzuki a call (888-samurai) I was just talking to them about an all steel dif front with a locker for my tracker and he was talking about using the samurai carrier in there because they are not making a lock rite for the front   yet though it is suppose to be out soon. (I think he said something about changing side gears).
94 Tracker, 30 x 9.5 tires,  2" lift.... Planning 34 x 9.5 tires, 3" body lift, 5.83 gears, Detroit EZ locker in Rear & fabricating external cage, Roof rack, Bumpers, rock rails and skiplates
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #3 on: March 25, 2005, 06:38:10 PM »
when i got my locrite  it said vitara/sammy on it....i would expect the spider gears are the same
« Last Edit: March 25, 2005, 06:38:51 PM by mbmarkyb »
Markyb (UK)
UK Vitara JLX SE
Offline purevil71
  • 261
  • Someday when I grow up, I wanna be hardcore too!!
« Reply #4 on: March 26, 2005, 01:12:30 PM »
The one in my Samurai came out of a Tracker
88.5 Samurai
Balls Deep 4x4 & Off-Road
I-Zook Staff
Offline xamtex
  • 72
« Reply #5 on: March 26, 2005, 11:58:15 PM »
the sammi lockright will fit the kick FRONT, the kick rear is different.......bigger alltogether................................
the kick front is the same size as the sammi,just a different ratio.also the kick diff has an ally casing which is weaker than the steel sammi casing.so for strength build the kick ring and pin into a sammi steel third using the sammi lockright..... ;D
god must love crazy people,he made so many of them!!!
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #6 on: March 27, 2005, 12:02:33 AM »
OK, so a sammi lockright will fit in a tracker front end, with NO modifications?
Time to start blowing the front end up!  8)
Offline Chief
  • 678
« Reply #7 on: March 27, 2005, 11:26:32 PM »
