venting engine!
venting engine!
budzooka
53
venting engine!
March 27, 2005, 02:45:37 AM »
I have put a toyota carb on my 1.3 and i would like to know what to do with the engine breather line that used to go to my air filter canister? I plugged it and ended up with some pressure and then some blow by from
any ways leaving it open just sends fumes into the cab and i have no line on the carb for it or on my air filter. any help would be appreciated.
Bigzook
2206
13
Current owner of the famous Audi Kick
Re: venting engine!
March 27, 2005, 03:07:15 AM »
I got one of those little ricer air filters and put it on the end. You could also use a fuel filter of correct size.
http://www.facebook.com/#!/pages/Donkey-Worx-Galleries/144890372136
[/url]
budzooka
53
Re: venting engine!
March 27, 2005, 03:08:21 AM »
thank you. what is a ricer filter?
bandit86
1641
elv8rguy
Re: venting engine!
Reply #3 on:
March 27, 2005, 03:50:10 AM »
drill a hole on the air cleaner assy and attach a fitting so that the fumes from the crankcase will be sucked in through the carb. you can find something in your local junkyard that'll work
prairie_dog
234
85/413 tin top
Re: venting engine!
Reply #4 on:
March 27, 2005, 03:30:37 PM »
Re: ricer filter, 1-2 inch round filter usually found on valve cover ( ford/chev V8 dress up kit)
budzooka
53
Re: venting engine!
Reply #5 on:
March 28, 2005, 01:25:00 AM »
thanks for the help. i have solved that problem and am off to the next one
