shackle reverse?? comments please.....
  • 40 Replies
  • 9528 Views
Re: shackle reverse?? comments please.....
« Reply #30 on: September 19, 2005, 04:47:56 AM »
Shackles at the rear works for Toyota
Offline 6feetofAIR
  • 127
  • i wanna go to hawaii yayyyyyyyyyyyyy yy
« Reply #31 on: September 20, 2005, 03:06:26 PM »
hey save the drama for your mama i wonder what the miracle equipment you are describing cost i bet it is 3 or 4 times the amount of the 5 1/2 lift with sr.
arguing on the internet is like the special olympics, even if you win your still retarded... :o
Offline explosivo
  • 3157
« Reply #32 on: September 20, 2005, 03:49:14 PM »
Same thing I was thinking while reading through this thread. You don't see ANY Toy guys going to front shackles.
Shackles in the rear is a better suspension design because of how it lets the axle move over the terrain.
omghi2.us[/url]
Offline andyt87
  • 146
  • I LPVE ZUKI WORLD!
« Reply #33 on: September 20, 2005, 11:34:38 PM »
wow... ive started off a big argument....  sh :ot...
Well, ive looked on www.puresuzuki.com and for the standard shackle reverse and a 3 inch body lift, it would cost £188 GBP, thats not inclding postage  :( which i think could be quite alot, maybe another hundred, i will have to email them an ask...
Do u think it is worth while adding the body lift aswell? or should i spend the extra cash on the 3.5" sr?
Also with the standard sr, would i need to buy longer shocks? or will the standard ones hack it?
Andy
1988 SJ 413
1986 SJ 410
1992 Samurai Sport
1989 Santana 410
« Reply #34 on: September 21, 2005, 04:41:59 AM »
Try Rob Butler at Rubbers Suzuki  (£145) and Rhino Ray (£180?) too.
« Last Edit: September 21, 2005, 04:54:26 AM by Rhinoman »
Offline 6feetofAIR
  • 127
« Reply #35 on: September 21, 2005, 03:04:39 PM »
body lifts are for trackers with independant front suspension, if its a solid front axle suspension lift is where its at imho
Offline nitromax
  • 206
  • FunZilla's alive !
    • NitroMax's Pages
« Reply #36 on: September 23, 2005, 10:55:26 AM »
Or both  8)
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on : www.nitromax.nl
International editor |removethispart|@ www.izook.com
Offline 6feetofAIR
  • 127
« Reply #37 on: September 23, 2005, 02:45:53 PM »
only if you like laying it on its side alot :P
what is the advantage of a body lift if you have a solid axle? if you want to run 44  inch tires then get the height from leafsprings so you have more flex. i drive past soooooooo many people that get 44 inch tires then get 12 inch blocks and use them without a panhard bar, plain stupidity imho. nope, no reason for a body lift i can think of with a solid axle.
Offline mudbug
  • Mudbugging
« Reply #38 on: September 23, 2005, 04:23:10 PM »
I have the calmini lift on my truck and love it.  The ride is a lot smoother and the approach angles have not changed.
P.S.  if you bother to put the lift on, do lock the diffs to complete the truck.  I recommend both.
Jeeps are for people who can't handle a Suzuki!!!
Offline nitromax
  • 206
    • NitroMax's Pages
« Reply #39 on: September 24, 2005, 12:11:15 AM »
I must admit I mainly did the bodylift to be able to close the hood with the Camden/Weber/RamFlo set-up, but I also like the height of the truck as it is now ( and I dó have higher leafsprings as well ! ) . Since we don't have rocks here to climb ( like you lucky b*st*rds have ;) ) tipping over is not too big a danger in the sand and mud.
« Reply #40 on: May 13, 2006, 04:48:20 PM »
Okay, I'm convinced I'm doing the calmini 2" shackel reverse http://www.puresuzuki.com/shackle_reverse.htm. I eventually want to get 4-5" of lift though... should I follow up with Calmini's 3" system http://www.puresuzuki.com/3_samurai.htm later down the road, or go with the Old Man EMU's http://www.roadlessgear.com/page/RGL/PROD/SU/ARB120 I hear so much about? I can't really tell what the pricing of the Old Man's are (as the web site doesn't specify if the price is per leaf, or for the pair).
Looks like if I did the Old Man EMU's it would be more $$$, as I would have to locate my own shocks and such :(
~J~
