shackle reverse?? comments please.....
  • 40 Replies
  • 9524 Views
Offline andyt87
  • 146
  • I LPVE ZUKI WORLD!
« on: August 27, 2005, 05:45:35 AM »
ive been reading up on the shackle reverse made by Calmini.  it seems to be the perfect probuct for me and my sj, it offers a 2 inch lift and a smoother ride with better road handling.....  i was just wondering if anyone on the forum has used the shackle reverse and if they have any comments about it.
or if anyone knows of a similar product i would be greatful to here from you
thanks again
Andy
1988 SJ 413
1986 SJ 410
1992 Samurai Sport
1989 Santana 410
Offline takai
  • 907
Re: shackle reverse?? comments please.....
« Reply #1 on: August 27, 2005, 11:39:43 AM »
I have been looking into this myself. I have a lot of time talking to Hawk. I would love to have some other input as well.
'Cause, I am to misbehave.
Offline Cwkick
  • 888
« Reply #2 on: August 27, 2005, 03:25:21 PM »
I installed one on a Sami that I used to own.  It was THE BEST thing I did to it as far as ride and tracking down the road.
If you are looking for a small amount of lift and a much better ride, go for it!
Cwkick
Offline Gary_Hill
  • 288
« Reply #3 on: August 27, 2005, 04:11:49 PM »
Dito ...shackle reverse GOOD  :)
Offline dsumers
  • 72
« Reply #4 on: August 27, 2005, 11:59:52 PM »
The only positive thing you will gain with a shackle reversal is a much nicer, softer ride.  Everything else is bad news, I  destroyed my last sami because of running a shackle reversal.  The big problem is your tires want to pull away from the hill  you are climbing causing you to pull the front tires off the ground.  This is what happened to me and I flipped over backwards then rolled several times.  Would never ever run a shackle reversal again !
Offline roeman
  • 62
  • 1994 sammy!
« Reply #5 on: August 28, 2005, 03:41:03 AM »
I was just wondering, does if effect your approach angle?
1994 sammy
1995 Vitara 16v
« Reply #6 on: August 28, 2005, 08:53:09 AM »
No, it looks like it does though. The Calmini shackle reversal requires longer shocks as well
Offline andyt87
  • 146
« Reply #7 on: August 29, 2005, 05:29:06 AM »
so the shackle reverse doesn't improve entry angle? and will make you tip on steep slopes, that doesn't sound too good :( if it requires new shocks aswell, does that mean i would have to buy 2" lifted shocks, or could i get some longer ones, as i was going to raise her a bit more at a later date (funds permitting :) ) and it would cost a bomb to buy another set of new shocks?!?!?
1988 SJ 413
1986 SJ 410
1992 Samurai Sport
1989 Santana 410
Offline ctrimmer
  • 15
  • I'm Rick James     Bitchhhhhhhhhhh hh  !!!!!!!!!!!
« Reply #8 on: August 29, 2005, 10:32:59 AM »
I have the Calmini Shackle Reversal for sale....asking $100 plus shipping...I live in Dover,Pa...does not include shocks. Let me know if anyone is interested. Chad
Offline andyt87
  • 146
« Reply #9 on: August 29, 2005, 11:41:48 AM »
i would be interested chad, however, i live in the channel islands, so the cost of postage would make it cheaper to buy from the UK mainland. Cheers anyway dude!
1988 SJ 413
1986 SJ 410
1992 Samurai Sport
1989 Santana 410
Offline Gary_Hill
  • 288
« Reply #10 on: September 10, 2005, 10:38:59 PM »
>>>The big problem is your tires want to pull away from the hill  you are climbing causing you to pull the front tires off the ground. <<<
 Every mod has its good and bad.  You have to understand the changes and modify your driving methods to compensate. Your theory that shackle reverse pushes you away from the hill is similar to what gas shocks do....I'm not gonna rip my gas shocks off my Sam simply because of their equalizing push away from the hill. I look at my angle meter and strap up when I'm in the red zone. Everything we do in our sport is a compromise.
Not trying to argue :)...just my 2 cents...Gary
« Reply #11 on: September 11, 2005, 12:53:37 AM »
I spray glue on my tires befor I go up a hill ;D  There are a million diffrent combinations for syspensions,I would like to go coil but the funds are not there,and they are more scary because the are more capable,so the more you do the more trouble you could get into(or out of)with the diffrent mods. no two zuks are alike unless there stock.
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
« Reply #12 on: September 11, 2005, 03:25:54 PM »
  HA, HA.  Ohh brother an angle meter.  Man do you guys play it safe.
Offline andyt87
  • 146
« Reply #13 on: September 12, 2005, 01:52:40 PM »
wow, theres quite a few different oppinions on the old shckle reverse aint there...... im not to sure what is meant buy "The big problem is your tires want to pull away from the hill  you are climbing "  is this just cos u can climb steeper stuff?? you really lost me
is there another shackle reverse kit availiable? or is it just the calmini?
cheers again
1988 SJ 413
1986 SJ 410
1992 Samurai Sport
1989 Santana 410
Offline flexmonger
  • 209
« Reply #14 on: September 12, 2005, 07:03:57 PM »
  WP Warrior offers a shackle reversal for the sammy. It can be bought at RRO or Roadles gear. It is a weld on setup and I think it possibly gives you better approach angle than the Calmini setup.
