calmini rear springs
  • 29 Replies
  • 6000 Views
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: calmini rear springs
« Reply #15 on: August 26, 2005, 05:42:21 PM »
Of course it also depends on how it collapsed... What were you doing when it went?
As for rear springs, you might want to check Ford Ranger/Exlplorer/Bronco 2 front coils. They might be real close...
Spring rate would be way off... I think whitfield is using these in the front of his rig... and I remember seeing that they're around 400lb/in or however they're measured, compared to the 150lb/in that a stock rear coil is.
Realredwagon is running explorer coils on his rig... not sure anymore which end he's running them on, though...
Legionnair: what were you doing when the spring collapsed? Did it drop as soon as you put the truck's weight on it, did it drop while traversing a speed bump at the mall or were you out in the woods when it happened?
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #16 on: August 26, 2005, 08:16:35 PM »
Seriosly, what the hell did you do when you collapsed the coil? Please tell, I must know! :o I am running the wrong shocks (flatens the coils to solid) and on an over weight kick (3500lbs) and I have had no problems at all.
Mike
Offline legionnair
  • 94
  • I hate working lets go wheeling
« Reply #17 on: August 27, 2005, 03:12:18 PM »
I was just running through a small trail in the woods not even in 4x4
and articulated a little and when I came back out i heard a bang as the spring slipped
back on to the saddle
first it was like 4 inches shorter so if you articulated it would come right out
then I was in the woods and it fell out so i used my winch an tied it to a tree and stretched
it now it is only 2 inches shorter it isn't falling out and it has been a month
but it still plauges me ???
OOps, owell thats just the fender
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #18 on: August 27, 2005, 08:56:05 PM »
Calmini shocks?
Offline legionnair
  • 94
« Reply #19 on: August 28, 2005, 11:37:06 AM »
yes the calmini rear shocks
Offline Digger
  • 1991
« Reply #20 on: August 28, 2005, 02:22:07 PM »
Did you extend the bumpstops or leave them stock?
Offline legionnair
  • 94
« Reply #21 on: August 28, 2005, 04:11:29 PM »
I left the bump stops stock
Offline Digger
  • 1991
« Reply #22 on: August 28, 2005, 05:18:58 PM »
That might have contributed to the problem. Doesn't the Calmini kit include bumpstop extensions?
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #23 on: August 28, 2005, 07:22:06 PM »
Even if it does ( I dont think so) I doubt it would be the problem. Mabey he just really got a bum coil.  :-\
Mike
Offline Digger
  • 1991
« Reply #24 on: August 28, 2005, 07:33:02 PM »
I reread the parts descriptions on Calmini's site and the 2" kit says it includes rear bump stop extensions, but the 3" kit doesn't mention them. It does sound like a bad spring for sure.
I wonder why the 2" kit includes the extensions(you can even see them in the pic)and the 3" kit doesn't(not even in the pic) :-\ ???
Offline legionnair
  • 94
« Reply #25 on: August 29, 2005, 10:58:07 AM »
because the 2 is just a lift it isnt made for big articulation
the 3 is made for the articulation
and I have looked over the parts list for the kit no mention
of anything to do with the bump stops
« Reply #26 on: August 29, 2005, 12:20:50 PM »
OK not trying to state something crazy but was one side on the front realy hard to get the strut attached? and/or does the front ride realy stiff?
(thinking front spring in rear on one side :-\)
If possible count the # of coils on each spring in rear, does it match?
Offline legionnair
  • 94
« Reply #27 on: August 29, 2005, 02:58:14 PM »
that is crazy first of all they are different sizes and lengths
and I am not that stupid
I know its the temping of the spring was not done right
because the bottom of the spring where it sits on the saddle is starting to flare out
Anyways I bought a spring from calmini and I am going to send the other one back and they said they would refund me the money
Offline robert_h
  • 30
  • 1.6 liters of fire-breathing power
« Reply #28 on: August 30, 2005, 06:13:56 AM »
I can confirm that the 3" kit doesn't extend the bump stops.
Glad to hear that Calmini is sending legionnair a new spring!
« Reply #29 on: August 30, 2005, 10:48:56 AM »
No offence intended, I have seen crazier happen with an install. Holy $^&*, it flared out in the cup  :o Good to hear it is taken care of :)
