What is the best power steering gear to run on the samurai with big tires?
  • 1174 Views
Offline dsumers
  • 72
I'm in the process of another sammy build up.  I would like to hear some opinions on the best steering gear to run.  I'm using a high pinion dana 44 up front.  I have heard the kick setup is too weak. I've been thinking about using a saginaw.  I  will be running 35" or bigger tires, haven't decided yet.  Some pictures of stearing gears would be greatly appreciated.  Thanks
some use ifs toyota, some fj 80 toyota, ect. get the arms from sky.
Offline dsumers
  • 72
I purchased a toyota ifs steering gear.  Does anyone have any pictures of install?  Is there anyone that makes a install kit?
Offline explosivo
  • 3157
There are a few companies that make kits to install the IFS box onto a solid-axle 'yota frame that includes plates and sleeves. You could probably get one of those and make it work with the Tracker frame.
omghi2.us[/url]
